Question about HP ProLiant ML370 G6 Server
Issue with power button of HP ProLiant ML370 G6 server.
I have a situation here with my HP ProLiant ML370 G6 server. It has the power button glowing in amber. But on pressing the power button the server does not power on itself. I have checked all the power cables to the server, reconnected them but no change. The front panel also does not indicate any warning like red, only the power button is glowing with the amber color. I would appreciate if I get any solution. Thanks in advance.
  • 596 Answers
I would check the the power supply to make sure they are seated correctly. Also, if you have intalled any new item, check to make sure it is seated correctly. If all are correct, you may have a faulty power supply or the en power outlet may not be correct specs for power needed.
Good luck.
Frank, N.I.T.
Posted on Jan 02, 2014
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
  • 28 Answers
SOURCE: i have HP ProLiant DL360 G5 Server i found
For Server-HP Proliant , Boot using SmartStart Cd(if you don't have download iso image from HP support site--Free & burn it to media)
Now boot using this Smartstart cd and choose Maintain Server...Use Diagostic options..to check hardware.....Also check Drives status....if amber light
Replace hardware or it is Contact HP for any hardware issue
Posted on Oct 10, 2009
info2u
  • 596 Answers
SOURCE: HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
Posted on May 28, 2010
Mikenet2620
  • 106 Answers
SOURCE: ProLiant DL160 G6 Server, Part
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Posted on Aug 16, 2010
Issue with power button in HP ProLiant ML370 G6 server
If i am not mistaken I belive that there are two power supplies, correct? what if you swap them? Or if you have a spare... I think that maybe either the button isn't working correctly or the power supply might have some issues...I also think there might be some LED lights on the power supplies themselves...check it out.
Jan 02, 2014 | HP ProLiant ML370 G6 Server
Hp proliant ml370 G6 ethernet controller, base system device and IPMI interface not configured properly
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Oct 20, 2012 | HP ProLiant ML370 G6 Server
DAT drive is not working.Tape once we insert comes out abruptly
Clean Tape drive using cleaning tape / Update Dat drive Firmware
Jul 06, 2012 | HP ProLiant ML370 G6 Server
I need driver of hp proliant ML370 G6
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/swdHome/?cc=us&cc=us&lang=en&lang=en&sp4ts.oid=3884311&ac.admitted=1399271691587.876444892.199480143
May 25, 2012 | HP ProLiant ML370 G6 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
I have a HP Proliant ML370 G3 server which was replaced can it be rebuilt for 64Bit Windows 2008 operation?
generation 3 servers do not support windows server 2008 there are no drivers for this OS
i include the OS Matrix for you to confirm
Oct 04, 2010 | HP Compaq ProLiant ML370 G3 Server
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
Startup problem
Assuming all appears normal (LED's etc) I would suggest you could have a Processor or VRM issue. Drop the machine to a single processor /VRM and see if that helps. Another possibility is a system board issue
May 27, 2009 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G6  Server Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
