Question about Kenmore HE2 Plus Front Load Washer
F33 error code - Kenmore HE2 Plus Front Load Washer
    Top Expert:
  • Kenmore Master
  • 14,162 Answers
Posted on Jun 16, 2015
4 Suggested Answers
SOURCE:
vickygomar
  • 460 Answers
SOURCE: ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
Posted on May 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: error code f33
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code f33 on an he4t
Posted on Sep 19, 2010
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
Mar 09, 2011 | Washing Machines
F33 error code
CLICK HERE
Thanks for using FixYa&^&^
Dec 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washer codes F01/F33, have cleaned the pump and
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f33 on an he4t
Oct 11, 2009 | Kenmore Washing Machines
F33 error code. drum begins to rotate and then
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code f33
Jan 25, 2009 | Kenmore HE2 Plus Front Load Washer
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
319 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
