Question about FAMOWOOD Adhesives, Coatings & Sealants
Still sticky first coat went well dryed very well ,but when I did a little stop fixing , them spots remain sticky after 6 months, now im getting ready to put a final coat on and would like to make sure it will dry really good again this time
  • 21 Answers
SOURCE: Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Posted on Sep 08, 2007
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Posted on Nov 30, 2008
SOURCE: DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Posted on Mar 28, 2009
How do I fix gloss paint that dried with multiple matte areas after second coat was applied? 1st coat went on fine and dried glossy.
the matte areas could be blushing from the paint
although the temp was 68 degrees it is the humidity in the air that causes the problem
when covering gloss with a second coat , it may be advisable to rough up the gloss coat first
Sep 17, 2015 | Rustoleum Stops Rust Brown Hammered Enamel...
Tip
Patching a hole in drywall/sheetrock
The best way to patch a hole when you don't have backing material is as follows:
Step 1: Cut the hole out square with a keyhole saw or utility knife:
www.all-wall.com/s.nl/sc.11/.f?search=keyhole+saw
Step 2: Cut a piece of drywall, (the same thickness as the wall that you are working on), to fit fairly tightly into square hole. (HINT: You don't want the patch to fit so tight that it breaks the corners when you try to put it in.) If done properly, this patch will not want to stay in the hole by itself. You must leave 1/32nd of an inch all the way around the patch. Once the patch has been properly fitted, you are now ready to start taping it in.
Step 3: Put the patch face down on the floor or table so that you can easily work on it. Using drywall mud/compound & the 5" knife, lightly mud the back side of the patch (www.all-wall.com/Categories/Joint-Knives/Hyde-Stainless-Hammer-Head). Place a piece of drywall tape over the patch, allowing it to hang over the edge of the patch about 1 1/2" on the top/bottom of the patch (paper tape flaps).(www.tooldistrict.com/2inx500ftpaperjointtapepn500bypermaglas-mesh.aspx) Holding the tape firmly against the patch, wipe down the tape with the 5" knife.
Step 4: Once the piece of tape is wiped down, you are now ready to apply mud to the section of wall where the paper tape flaps will be laying. Place the patch over the hole, tapping it into place until the patch is laying flat on the wall. Holding your fingers on the seams of the patch, wipe down the first paper flap, and then the other. (HINT: Always wipe down the top flap first, then the bottom flap. Make sure the patch is flush with the wall, or recessed slightly. If the patch is sticking out from the wall even a little bit, it will be very difficult to hide!)
Step 5: Now that the patch is in, mud the horizontal seams in, paper tape, and wipe down. Repeat the process for the vertical seams. (NOTE: You may use mesh tape on these seams if you wish because mesh is a little thinner than the paper tape; making it a little easier to cover on the next two coats. Don't make a special purchase if you don't already have some laying around, it's not worth it. ( www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape )Let this dry for 12 hours before coating again.
Step 6: For the next coat you will need a 10 " broad knife (www.all-wall.com/Categories/Taping-Knives-Stainless-Steel/Hyde-Maxxgrip-Extruded-Back) Apply mud to the patch, covering the tape from the previous application.You will need to leave more mud around the outside of the patch; not too much on top of the tape. It is already going to be a little high on top of the tape so you are basically creating an optical illusion by building up around the patch. Let this coat dry 24 hours.
Step 7: If the 2nd coat was done properly, then putting a finish coat, (3rd and final coat), won't be a problem. This coat is just to fill in any low spots that you weren't able to get completely full the last coat. And if you did get it full the last time, congrats, then it is just a skim coat to fill in any air bubbles that may exist. (NOTE: Whenever patching over an already painted wall, the drywall mud/compound will bubble. This is normal. After 2nd coat of mud drys, scrape off the air bubbles before applying the next coat.) Let this coat dry for 12-24 hours
Step 8: Now the fun part begins: Use a sanding sponge or a sanding pole to sand the patch off, (http://www.all-wall.com/acatalog/A000_Dustless_Sanding_20.php). Then it is ready for paint!!
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing, but as you can see, just a simple patch is very involved. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard, Patching, Texturing, Speckling, & Paper Tape
on Dec 01, 2009 | Hand Tools
Im getting ready to put my 91 camry on a 5hr road trip and am just a little nervous about it. any advice?? its had a few problems in the past, but i seem to have gotten them taken care of. Any extra...
Heres what i would do.
1. Check oil
2. Check trans fluid
3. Check coolant
4. Check brake fluid
5. Check your belts
6. Check spark plug wires for burnt spots or dry rot
7. Check your hoses
8. Check your tire pressure. <--- Very important
9. Check battery termanals
10. Make sure you dont forget your wife as this could lead to a disaster :)
11. Have a nice trip
Aug 06, 2010 | 1991 Toyota Camry
Spilt coffee over keyboard
It might be :-( and usually stuff that lack isn't covered unless you pay extra for a high end warranty.
There are a few things you can do to try to save it though. As long as nothing shorted out (you didn't smell anything burning did you?), chances are a good cleaning could fix it. Are the keys sticking? Most laptops nowadays have a small try under the keyboard to keep stuff away from the vital electronics in case of situation such as yours.
1) Power down the laptop and remove the battery
2) Gently pop the keys around where the spill occurred, just pry them with your finger nail, they should snap right off with a little encouragement
3) Take a damp rag and blot up any remaining spills, or sticky spots, remember liquids and electronics dont mix so go easy on the water.
4) With a dry rag, blot up any remaining wet spots, can hurt to let it sit and air dry for a few minutes as well.
5) Pop all the keys back on and hopefully you'll be all set!
Feb 04, 2010 | Apple MacBook Mac Notebook
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
My Chinon 10x25R binoculars have the same problem.
Simple use soft lint free cloth like old drying up cloth, you need about half a cup of methalayted spirits,can get this from any hardware store.
poke finger into cloth dip into meths proceed to rub sticky coating off binoculars. you will need to keep changing to a new peace of the cloth as soon as it gets coated with the sticky black stuff off binoculars.
keep dipping into meths eventually after say 6 rubs in a particular area you will see and feel a nice hard black plastic, continue all over effected area then finish off with any window cleaner polish until cloth remains clean.STICKY COATING IS NOW GONE IT WAS INFACT A COATING PUT ON THE BINOCULARS TO MAKE THEM NONE SLIP. job done. regards GER8
Jun 09, 2009 | Winchester 10x25 Hunter's Grip Binoculars
Steering wheel vibrates when i apply brakes. I have replaced rotors, calipers and breaks 3 times and the problem comes back after about 6 months or so. Any Ideas? Is this a flaw in design? are the breaks...
yes i have heard of this.check your tierod ends just to make sure they are good.But im sure its just those rotors warping.The next time u need brakes buy slotted and drilled rotors.they are pretty cheap on e bay.that allways fixs the problem you are having.The only other thing you can do if you dont want to upgrade rotors is. to keep the rear drum brakes adjusted.If you even have them.Come to think of it if you are having this problem with 4 wheel disk.then you might be having a problem with the combination valve. or the proportioning valve.But i think its just the rotors.
Mar 11, 2009 | 2002 Dodge Intrepid
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dull Round Spot
I cleaned via computer the printer and the matter was solved.
Nov 25, 2008 | HP Photosmart A617 All-In-One Printer
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Adhesives, Coatings & Sealants Logo
367 people viewed this question
Top FAMOWOOD Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a FAMOWOOD Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
