Question about Craftsman Drills
I need the schematic for the craftsman #1425301 7.2v - 24v battery charger to find out the value of a burnt out resistor. Can anyone help?
The charger gets power but will not charge the batteries. I know the batteries are good and when I opened the unit up, the fuse was not blown. Any ideas?
emissionwiz
  • 76673 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
  • 115 Answers
SOURCE: I have burnt out one of the resistors in my 18
MOST OF THE TIME MANUFACTURERS DOESNT SELLE DIAGRAMS,BECOZ THE WANT ONLY TO REPAIR THEIR PRODUCT BY THEIR CERTIFIED TECHNICIANS.
Posted on Oct 22, 2009
radar001
  • 1051 Answers
SOURCE: My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Posted on Feb 21, 2010
SOURCE: dc9700a charger schmatic
Check that the black microswitch is operating when a battery is placed in the charger. The microswitch button is pressed by a blue plastic piece. Over the years, the part of the blue plastic that the battery slides over wears down so that the switch does not operate. You can check it by slowly inserting a battery and listening for the switch to click.
I made a temporary fix by grinding down a stop on the blue plastic actuator so that it sticks more into the battery well, then wrapping tape around the portion that actually presses on the switch.
I doubt that you will be able to purchase that plastic actuator, but you might be able to find a used working charger on your favorite auction site.
Posted on Apr 03, 2010
puertobori
  • 7733 Answers
SOURCE: I have one Makita battery
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
I have a 1992 Rascal, Model 240. The charger assembly has a burnt mark on it. Is there a schematic or picture of the board that I can get? My brother may be able to fix it, but he can't identif
The charger is a 24v 4 amp one stage device. Its an incredibly cheap charger. It consists of a step down transformer, a bridge rectifier, a filer capacitor, and a voltage regulator. Virtually all chargers are made this way. Generic schematics
http://www.simple-electronics.com/2011/10/24v-battery-charger-simple-and.html
This charger is built around the famous an popular LM317 chip it really simplifies things.
http://www.circuitstoday.com/24v-lead-acid-battery-charger-circu
I would get out my trusty multimeter and chase 24v though the device.
You may need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Set the meter to read VAC, you should get 30VAC out of the transformer. Next check the rectifier section, Set the meter to read VDC, the output should be about 29VDC. There is a fuse in there that you can check out. Then there is the regulator, if any part of that is fried, you're going to have a hard time finding parts. i really miss the 60's when there were electronic stores on every corner. There used to be a time when you could order your your TV as a kit. You could literally teach your kids something useful at the kitchen table. Quite frankly a 2 amp charger cost $14 4 amp cost $28. Not worth fixing really.
Chargers can be found here
http://www.amazon.com/Electric-Scooter-Battery-Charger-Prong/dp/B001GMTKN4
Jun 19, 2012 | Electric Mobility Mobility Electric Power...
Hi, my B & D 24v slide in battery charger 5145093-00 stopped working. I've opened the slide-on end, and discovered a blown resistor. The a.c. is still being rectified to approx 26VDC If i knew the...
Hi daggsat, I know this is a longshot but did you ever discover the value for the resistor for you B&D charger. I've got exactly the same problem.
Jun 13, 2011 | Black & Decker Vacuums
I have 110 volt durapro 18volt dc battery charger, component R14 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
The component is a resistor. The problem is going to be determining the resistors value since it was burnt and you can not see the color code. You might try contacting the manufacturer and asking them the value of that specific resistor by including the number like you did in your post R14. If you can find a wiring diagram for the product, it should tell you the value of the resistor also.
I hope this helps you getting started in solving the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Alpine MRP 200 could you pls tell me valu of
I don't have a schematic for your deck however, if the resistors you need are not burnt beyond visibility, this PDF should be alot of help. http://www.electro-tech-online.com/electronic-theory/42899-resistor-colour-code-values-chart.html Hope this helps
Jun 06, 2009 | Alpine Car Audio & Video
Resistor burnt up, inable to identify due to skorched bands
I have the same exact problem in a 12 volt Lincoln battery charger. Burned resistor in R5.
May 07, 2009 | Lincoln 14.4 Volt Cordless Grease Gun,...
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Drills Logo
159 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
