Question about Tissot T-Touch T33159851 Wrist Watch
Sleep mode on a tissot - Tissot T-Touch T33159851 Wrist Watch
My Tissot touch will no longer sync - initially when in compas mode the hands were no longer aligning in a straight line and after using the compas mode i need to resync each time. Now the watch will not...
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
Jan 17, 2018 | Tissot T-Touch T33759851
Hi, My Tissot touch watch quit, it was just over 2 yrs old, and I took it to the local Jewelry Store that sold them. They sent it off to their Jeweler and he replaced the battery. Now the watch keeps...
If the Jewellery Store was not an Authorised Tissot Repair Centre then it is likely that they have made a mistake - the T-Touch is the only watch in the world that has a touch screen - so they may not be very familiar with it.
It may be going into setup mode because there has been a new battery just installed - go through the procedure and see if it works. - Pretend it is like brand new and you have to set it up for the first time.
Dec 14, 2010 | Tissot T-Touch T33159851 Wrist Watch
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
The digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Dec 07, 2009 | Tissot T-Touch T33759851
My tissot toch hour and minutes are out of sync for instance at 10:45 it appears like the hour is on or past 11. Is their any way to re-sync them or reset them.
This is an expected, needed adjustment, and is addressed in the manual:
http://www.tissot.ch/data/usersmanual/138-en.pdf
Syncronisation
Sep 11, 2009 | Tissot T-Touch T33759851
Tissot t touch
there are sync instruction on the manual page on the web.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Centre Sensor no longer functioning
You are need to send it into tissot for a service. You cannot fix this problem on your own. There is a two year warranty for tissot. Hopefully you will be eligible.
Apr 04, 2007 | Tissot T33.1.588.71 Wrist Watch
Tissot T-Touch T33159851 Wrist Watch Logo
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
