Question about Epson Office Equipment & Supplies
How to change paper thickness
I am trying to print business cards on 240 gsm paper but it wont feed through the printer, is there any way to change the paper thickness type on the epson DX8450.
Basti
  • 1447 Answers
SOURCE: Epson DX8450 not printing
are you using leopard os x? when you said you loaded the driver for the printer, did you use the disk that came with the printer?
Posted on Apr 04, 2008
  • 7 Answers
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Posted on May 30, 2009
aicaxz
  • 511 Answers
SOURCE: Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Posted on Jun 30, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
Wont print on card
It is possible that the card thickness is to big for the printer to "pull" the card in. try using a thiner card, giving a small **** of the card to assist the printer while "pulling" the card, or try cleaning the small wheel it has in the paper drawer for pulling paper with amonia.
Jan 24, 2012 | Ricoh Aficio AP3800C Laser Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Paper will not feed into printer epson r300 printer It tries but does not feed
This is a common prob of all epson printer. If you use more than 230GSM thickness paper with the printer and use 80 gsm paper next, it wont pick up. This is due to the spring in the back side of the paper picker unit elangated to more thickness and fail to function fully. you can remove the paper pickup unit and change the spring if you have the service manual.
Aug 10, 2009 | Epson Office Equipment & Supplies
Not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Aug 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
My business cards will not print from Printmaster Gold to HP 2410 Printer. Everything else prints except business cards. I get a box that indicates the are printer but nothing prints.
your cards are too thick .the printer wont actually move the card down to yhe printing heads. try placing just one sheet into the printer or/and go to setup and see if you can set the printer for thicker paper try user defined setting. no promises.
Apr 19, 2009 | Broderbund PrintMaster Gold 16 for PC
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Print Garbage
The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
613 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
