Question about GPS
HOW TO CONNECT PRINTER TO COMPUTER - GPS
Why my hp computer will not connect to a wireless hp printer
You computer does not connect directly to your printer. It connect via your router, so you need to make sure that your router and the printer is connect using the WPS function or entering the routers control and panel. Alternatively uninstall the software for the printer and re-sintalle. During the re-install you will be asked how do wish to connect to the printer, select wireless and make sure you enter the router's passkey and the type of encryption uses. Problem solved.Cheers.
Jun 05, 2014 | HP Photosmart C3100 series
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to update a new ip address in order to get my printer print?
I think IP address is not a problem in your printer. You just need to check if the printer driver is install to make your printer work...
IP address is only use to connect the computer to the internet not to connect with the printer. If you have a printer connect to other computer you really need to configure the IP of both the pc to connect each other...
Router will automatically assign IP address of those computer connected to a routers. If you still not connect
Please don't hesitate to ask again and I will give you the step by step to configure your IP address unless your connect with static IP
Sep 20, 2011 | Xerox Phaser 6125 Laser Printer
FI'm trying to instal a new Hewlett Packard printer on my Dell computer I keep getting a message to connect the printer cable to the computer
dont connect the printer unless it ask you to connect.
at the time of installation it will ask u to connect the printer.
Aug 05, 2011 | Office Equipment & Supplies
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Suddenly, my hp printer won't print. I use
try to remove everything from printer that connect to you computer, from you pc remove driver restart and connect your printer it must be a pop up that found new hardware to you computer. in not then you computer not detect that printer. try to replace printer cable. if still not work tr to connect your printer to other computer to conclude where the problem. from printer or from you computer. please give feedback for next trouble shooting.
Apr 13, 2010 | HP PSC 1610 All-In-One InkJet Printer
Connecting to printer through network
What operating system are you using? If it is xp it is very easy. Right click on your printer on x computer and click sharing and share it with an easy name like HP Laser, then on y computer open run command by going to start and run and in there you will type in \\xcomputer name which you can get by right clicking on my computer on x computer and choose computer name. once this is typed in run on y computer press ok and you will get window with some shared folders and also a printer. Just double click on printer and it will ask you to install drivers and it will connect but your x computer has to be on to be able to print from y computer.Same principle with 2 vista computers. If one is vista and one is xp this might be little more involved. Hope this helps.
Jan 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to connect and install driver to the printer
The HP 640C will connect to a PC with either a parallel or a USB cable. If you are connecting to a Mac computer, you will connect to your PC with a USB cable. I would recommend the USB cable for either the Mac or a PC as it is a better connection. If you do not have either of those cables you will need to buy one from your local computer accessory store. Turn off your printer and computer. Connect your cable to the printer and computer. Then boot your computer, and once the bootup finishes, turn on the printer. At that point you will have to install the software driver cd that came with the printer. If you do not have the software you can go to the HP website and download the correct drivers for your computer.
Jul 07, 2009 | HP DeskJet 640c InkJet Printer
HOW TO CONNECT PRINTER WITH PC?
first you have to connect with the power
then use the printer cable to connect the printer with your pc.
If you can mention the printer i will tell how to connect with the pc
Normally in new printers they use the USB cables to connect printers.
OR the parallel port to connect printers like dot matrix ( in this port there are only one port are in the behind the CPU it is a normally biggest connector )
Nov 07, 2008 | Epson LX-300 Matrix Printer
GPS Logo
26 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
