Question about Beats By Dr Dre - Wireless Bluetooth Over-the-Ear Headphones - Black 128876-00
They smell like they burning when charging.. They keep getting hot when charging
  • Beats By Dr Dre Master
  • 5,190 Answers
Clearly a fault of some kind! If they are still under warranty contact the maker etc. If not find a suitable repair centre. The makers website will be able to help. I recommend that you cease using them till the fault is sorted (fire risk).
Posted on Jan 03, 2014
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
Drill's charger gets hot
sounds like you have a battery problem and I would think that it has also damaged the charger.
Apr 08, 2012 | Makita Drills
Check engine light + hot smell after driving only 20 miles
Make sure your alternator is not seizing up making the belt slip and get hot enough to smell of burned rubber.
Feb 09, 2010 | 2003 Ford Escape
I have a hoover mach 5 multi-chamber cyclonic vacum cleaner and it keeps getting hot and quitting.it's got a strong smell like something is burned when it gets hot also.
if its giving off that strong smell then the motor is bad. probably caused by not keeping the filters clean. on any bagless machine one has to clean the entire vacuum after almost every use to keep the unit operating correctly
Dec 31, 2009 | Vacuums
Smell of electrical burning.. no more heat in house!
First of all keep this in mind.
You will need to locate the wires that got hot. If you can't or if your not sure, I suggest that you call a service company. If they ok the unit and it catches on fire after wards, their insurances will cover you unit and or home if god forbid it burns. This is to be on the safe side.
Now, this is where I would look. Your element should be on it's on circuit. There should be a disconnect within reach of the air handler. Some are fused and some are not. The wires that got hot enough for you to smell them should show signs of being hot like the plastic will be melted around the wire. You said that the heater was running. Was this the first time you have used it this year? If so, are you sure it was not the dust burning off the elements? They will smell like something burning when you first turn them on each year. Although if your sure you smelled wires getting hot, please continue looking for just that. Keep in mind that the elements have 220 volts coming to them. It comes into the unit and go to a switch or relay. From there the power goes to the elements and then to a neutral. These are the wires you will need to pay the most attention to. Good luck.
Nov 23, 2009 | Heating & Cooling
My hot tub pump is getting loud. And if placed on high I can smell a burning smell, so obviously not being used. I've left it on to keep it heating and the plumber is scheduled for this week. However...
It sounds like the bearings have gone bad in the jet pump. A shaft seal leak will sometimes let water get into the bearings and the motor will get louder and louder. Running it on high can intensify the noise and heat created by bad bearings. Eventually, the bearings will seize and the motor will try to turn and since it can't, it will get really hot. The motor has built in high limits to keep from burning up completely but it will smell like it's burning. I would replace the pump motor and seal, should take care of the problem. The OH may have been caused by the pump not moving enough water to run the heater and tripped the heaters high temp sensor. I hope this helps.
Oct 13, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
"rubber burning" smell
check to see if the motor is overheating, the motor could
be getting hot causing the smell, if the motor is'nt overheating, then call the local repair man, we live in miami(florida), and we have a dish washer that keeps on rumbling, we are getting it fixed today, the only big big problem is it seems to draw alot of electricity when in operation, so there's my problem
p.s. is your dishwasher also rumbling and drawing electricity?
shawn henks
miami,fl
Nov 26, 2007 | Asko D1716 Built-in Dishwasher
Beats By Dr Dre - Wireless Bluetooth Over-the-Ear Headphones - Black 128876-00 Logo
138 people viewed this question
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
