Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Low water flow and pressure
Low water pressure and flow from a Grohe Europlus II dual-spray pullout kitchen faucet. I removed the cartridge, and found no sediment or other blockages. Also removed the aerator. No blockages there either. Very annoying.
    Problem Solver:
  • 5 Answers
U can also remove the pressure regulator. It is usally a black ring with small hole or to rubber washers together.
Posted on Jul 28, 2009
  • 115 Answers
Remove aerator and cart. and soak in limeaway over night
Posted on Jul 26, 2009
My Grohe kitchen faucet pressure is terrible, I believe I need to replace the screen. Can you help
Not sure if you fixed this yet, but I know that this faucet has a flow control option on it that you might want to adjust.
Dec 29, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a grohe ladylux that is almost 3 years old. the water pressure is low. When i unscrewed the head water flows well, but when the head is back on it rens slowly. I,ve cleaned the screen by unscrewing...
On this particular faucet you may not be able to reach the part that might be giving you issues in the spray head. However, to take the head apart, on the spray face you will turn it counter clockwise, the aerator will come out at that point and you should be able to see down into the tube to see if there are any obstructions. Also if you are using the little Grohe water filter that goes into the handle before attaching the hose, it is possible that that is clogged especially after 3 years. You should be able to remove that altogether, or contact Grohe for a replacement. If once you have removed all of these and have found no removable obstructions, then the only other thing to do is contact Grohe for a replacement spray head which I believe they are still available. Hope that helps.
Aug 18, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
I have a brand new Europlus faucet with hardly any water flow. I had the first Euro faucet with good flow. Why is the water flow so low on a brand new faucet.
when you installed did any teflon tape or debris get inside? you can remove and reverse flush with hose and it may clear the blockage
Jul 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
1,278 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
