Question about Lenovo Cell Phones
Service menu codes - Lenovo Cell Phones
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
Tip
Service codes Chinese models
  1. Service codes "Chinese" models:
  2. default user code: 1122, 3344, 1234, 5678
  3. Engineer mode: *#110*01#
  4. Factory mode: *#987#
  5. Enable test mode COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
  6. Restore factory settings: *#987*99#
  7. LCD contrast: *#369#
  8. software version: *#800#
  9. software version: *#900#
  10. Service codes BenQ:
  11. software version: *#300#
  12. test mode: *#302*20040615#
  13. Service codes Pantech:
  14. software version: *01763*79837#
  15. service menu: *01763*476#
  16. reset defaults (phone/user code reset to default): *01763*737381#
  17. Service codes VK-Mobile 3xx, 5xx:
  18. software version: *#79#
  19. software version: *#837#
  20. service menu: *#85*364# (hold #)
  21. Service codes VK200, VK2000, VK2010, VK2020, VK4000:
  22. software version: *#79#
  23. service menu: *#9998*8336# (hold #)
  24. reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
  25. Service codes LG:
  26. software version: 2945#*#
  27. Service codes Sony-Ericsson:
  28. J100 software version: #82#
  29. Service codes Fly:
  30. M100 software version: ####0000#
  31. 2040(i) reset defaults: *#987*99# Send
  32. MX200 reset defaults: *#987*99# Send
  33. MX200 software version: *#900# Send
  34. SL300m reset defaults: *#987*99# Send
  35. SL300m software version: *#900# Send
  36. SL500m reset defaults: *#987*99# Send
  37. SL500m software version: *#900# Send
  38. MP500 reset defaults: *#987*99# Send
  39. MP500 software version: *#900# Send
  40. Set language to English: *#0044#
  41. Set language to Russian: *#0007#
  42. Service codes Konka:
  43. C926 software version: *320# Send
  44. C926 set default language: *#0000# Send
  45. C926 set English language: *#0044# Send
  46. Service codes GStar:
  47. GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
  48. Set language to English: *#0044#
  49. Set language to Russian: *#0007#
  50. Service codes Motorola:
  51. Motofone F3 software version: **9999* Send
  52. C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
  53. C138, C139, C140 software version: #02#*
  54. C155, C156, C157 software version: #02#*
  55. C257, C261 software version: #02#*
  56. V171, V172, V173 software version: #02#*
  57. V175, V176, V176 software version: #02#*
  58. C168, W220 software version: *#**837#
  59. W208, W375 software version: #02#*
on Mar 07, 2010 | Cell Phones
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Service codes BenQ:
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
Need codes to display service menu for esa et427e
This is a Funai product. Factory reset may be 1 2 3 4 DISPLAY. But Funai manuals I have refer to a "Service Remote" to enter service menu.
Mar 13, 2010 | ESA ET427E 27" TV
My InFocus Proxima DP6150 has images with red outlines shifted to one side. colors appear to be separated. Is there a way to fix this?
Service Code
The service code to enter the service menu is as follows:
` Press menu, then service, enters the following: Magnify Volume up, Volume down, Power, Menu, Source and enter.
Nov 25, 2009 | InFocus Proxima DP6150 Multimedia...
How can I reset the service light on my aprilia pegaso strada.
DIAGNOSIS
This menu interfaces with the systems fitted to the
motorcycle to carry out diagnosis. To enable the menu, a
password is needed that is available only to aprilia service
centres.
• Insert the service code
It is a 5 digit code, for Pegaso the code is: 25973
If code is wrong, appears the message:
• Incorrect code
The instrument panel goes back to main menu; if not, the
menu appears:
• EXIT
• ECU ACTUATIONS
• ECU PARAMETERS
• ECU ERRORS
• DASHBOARD ERRORS
• DELETE ERRORS
• SERVICE RESET
• DISCONNECT
• UPDATE
• UPDATE KEYS
• KM / MILES
Once the operation is over, the instrument panel goes back
to main menu.
Jul 12, 2009 | 2007 Aprilia Pegaso 650
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Lg unlocked '
If it's the childlock, you can change that in the menu.
cheers, Gerard
Nov 07, 2008 | LG 42LC2D 42 in. LCD HDTV
SERVICE MANU OF MY SANYO KIT
I HAVE A SNYO KIT ( 360 CHANNEL ) USING MICROPROCESOR IC LC863532C-58E2 I WANT TO KNOW THE CODES OF SERVICE MENU & HOW TO UNLOCK TV CHANNEL
May 31, 2008 | Sanyo DS24205 24" TV
Messed with with service code menu now i dont have service with my wireless provider
it is software problem cunnect it to pc and unlock service code othewise went to sarvice center
Aug 10, 2007 | LG VX5300 Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Lenovo Cell Phones Experts
james laughton
james laughton
richie46
Are you a Lenovo Cell Phone Expert? Answer questions, earn points and help others
