Question about Slideout Cover Awning 146 In 153.9 In Roof Range White Vinyl
Schwintek RV slide out adjustment
Schwintek Slide out is sticking out 2 inches more at the bottom than the top when fully retracted and causes one end to dig into the floor as it retracts.
Where is the motor for the slid out on a 28 ft RV
if gears on sides of slide schwintek motors inside on top behind sweep seal if ram type slide motor on slide under
Apr 07, 2017 | RVs
Kitchen slide will only go out 7 inches. it stops. it retracts ok but only goes out 7 inches and stops. are the cables suspose to be slack
I can only assume this is an RV you are talking about. No there should not be slack. I would start by finding the manual slide out mechanism. It will be a hand crank type or unit. Manually slide the kitchen unit out and then try to slide it back in with the button. That will either bring it all the way back in or you can see that the motor is bad or the limits are off.
Apr 19, 2016 | RVs
How can i manually retract slide-outs on 2012 sunnybrook raven 2980bh?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiujIee3vLLAhWC5yYKHZ1SCwkQFggfMAA&url=http%3A%2F%2Fwww.amlrv.com%2Fsite%2Fwp-content%2Fuploads%2F2012%2F10%2FSchwintek-Manual-override.pdf&usg=AFQjCNF4nHMGsdcMNW1CybT4wr0BAfN4uQ&sig2=EaweHZyC2VaQhuC0NBpjPw&bvm=bv.118443451,d.eWE IIF this is a Schwintek slide system, this is the way you do it. If hydraulic then there is a valve near the motor/storage tank where you turn and then you insert a rod and pump it like you would a hydraulic jack. Electric motor/track slide outs you disconnect the motor and there is a place you manually turn it in.
Mar 27, 2016 | RVs
Adjust slide out on heartland prowler
The slides are designed to tip and drop when coming out so that when fully extended they will be flush with the floor. When coming back in the bottom will pull in first and cause the top to tilt out until the slide fully closes and the weight transfer back to balanced and the slide properly seals. When the slide is all the way out is it sealed all the way around? If it is then you do not need to adjust. There is alot of weight being balanced at two connecting points under the slide. If it does need to be adjusted you are better off taking it to someone who knows what they are doing.
Oct 28, 2014 | Heartland 2013 Prowler Resort Res 39 BH
Slide out repair
Slide adjustment is not an easy task because there are a lot of issues to take into account. One small adjustment below could throw the entire slide further out of adjustment. There could also be structural issues where the floor or walls are weak and no amount of adjustment will help. You are better off spending the money to have a trained technician make the necessary adjustments and save yourself from a lot of frustration down the road.
May 06, 2014 | RVs
I have a northwood rv and the slide out is compressing the top rear seal to the point that it is damaging the seal. How do I adjust the slide out the fix this problem?
normally not adjustable from my experience you might check the bottom runners is they are filled with dirt or have something could in one it will cause the problem
Aug 29, 2013 | Vehicle Parts & Accessories
NO AUTO MOVEMENT USING SWITCH ? ?
1. Pull the tape out about 12-18 inches.
2. simultaneously pull the slider switch on the bottom and the switch on the top.
May 27, 2013 | Black & Decker Auto Tape Measure
De dietrich oven , panel shows er2
Tools- philips scredriver, Torx screwdriver
Disconnect from the mains. Open the oven door- use a screwdriver to lever the latch up if it's still locked. Unscrew the 2 screws that hold the oven in the carcass. Pull the oven out from the unit about 6" (you don't need to remove it). Undo the 2 torx screws on the top of the oven and push the top cover of the oven back to reveal the electrics. On the left hand side you'll see a black plate with a reddy brown actuator and a switch. Remove the black plate by taking out the 2 torx screws from the left hand side of the oven. Unclip the switch from the black plate and push it to one side (you don't need to disconnect the wires). Disconnect the reddy brown actuator wires (red on left, black on right although it doesn't actually matter). Remove the plate complete with actuator. Pull the front of the actuator up and slide out forwards, releasing the whole actuator. Don't lose the spring! The little piston at the front of the actuator should only be sticking out a few mm (about 3-4). If it's sticking out more, then it may be stuck. So...
Seperate the 2 halves of the actuator by twisting the bayonet. The actuator half should have it's piston fully retracted, leaving a little flange sticking out. If it's not fully retracted, the actuator is toast and needs renewing. If it is fully retracted, pull out the 2 black parts and the plunger from the part you twisted off the actuator and make sure they are free and not sticking (this is what was wrong with mine). Reassemble the actuator and clip back into the black plate with the spring behind it. Reconnect the power cables. Install the switch. Install the sub-assembly in the oven. Replace the top cover of the oven. Slide oven back into the unit carcass.
Done!
Thanks
Apr 02, 2012 | Ovens
Vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Dec 12, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Slideout Cover Awning 146 In 153.9 In Roof Range White Vinyl Logo
108 people viewed this question
Top Carefree of Colorado Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Carefree of Colorado Vehicle Part and Accessory Expert? Answer questions, earn points and help others
