Question about Garden
How do you remove head - Garden
I. Need. Help. With. Cam bolts. And head bolts
Part 1 of 3: Getting to the head bolts
Materials Needed
  • Eye protection
  • Gloves
  • Oil and coolant drain
  • Parts cleaner or brake cleaner
  • Shop rags
  • Socket set and ratchet1: Drain the oil and coolant. Put on your eye protection and gloves and drain the oilfrom the vehicle.
    Make sure the vehicle can not be started by removing the negative cable from the battery. Next the coolant will need to be drained so it does not leak when the head bolts are loosened.
    Step 2: Clean valve cover. Use some of the parts cleaner or brake cleaner to clean up the valve cover and as much of the cylinder head as is reasonable.Remove valve cover. If necessary, remove other components to make the valve covers accessible, and start removing the bolts from the valve cover.
    Once all bolts are removed carefully removed the valve cover from the cylinder head. If any valve cover gasket material remains, remove it at this time and clean any excess oil from the edges. Set the valve cover aside carefully as it will be reused with a new gasket once repairs are completed.
    Part 2 of 3: Pushrod engine head bolt removal
    Materials Needed
    • Head bolt socket (if needed)
    • Numbered cardboard
    • Rubber hammer
    • Socket set and ratchetStep 1: Rocker arm and rocker removal. A pushrod engine has long pushrods that protrude through the cylinder head and attach to the rocker rail.
      The rocket arm will need to be loosened first. Many manufactures have a specific sequence for removal of the rocker arm bolts. After the rocker arm is removed, the rockers will be unbolted.
      Set all rocker arms aside in the order they were removed as they should go back to the cylinder they were removed from.Step 2: Remove the pushrods. Remove the pushrods one at a time from the cylinder head.
      Put them into a numbered piece of cardboard as the pushrods will go back into the same slot they came from.Step 3: Loosen head bolts. Use the ratchet begin to break the cylinder head bolts loose.
      Each bolt will be loosened but not removed. Loosen all of the bolts before removing any of the the bolts all the way.
      Step 4: Remove the bolts. Place each bolt through a numbered hole in the cardboard in case the head bolts are different lengths so they can be installed back into the proper hole.
      The bolts may require a special socket depending on the manufacture.
      Step 5: Lift off the cylinder head. Once all bolts are removed, lift up on the cylinder headgently; the head should come free easilyIf the cylinder head sticks, lightly use a dead blow or rubber mallet to tap the cylinder head to be able to remove it. Set to the side in a safe area.
      • Warning: Cylinder head bolts have a specific sequence that is used when removing them. Consult the manufacturer's specifications for the proper removal sequence for the engine being worked on.
      Part 3 of 3: Overhead cam head bolt removal
      Material Needed
      • Socket set and ratchetStep 1: Remove the timing cover. The timing cover will need to be removed to gain access to the timing belt or chain.
        This is necessary because the cam shaft sits in the cylinder head and is attached to the crankshaft with either a timing belt or timing chain.
        Step 2: Time the engine to remove the belt. The engine will need to be timed to avoid damage when the timing belt is removed.
        Each engine is different and will have its own procedures to time. There should be marks on the camshaft and crankshaft that will be aligned to set the timing at top dead center (TDC)Step 3: Remove the timing belt. The timing belt tensioner will be removed or released to take the tension off the belt.
        Once the belt is loosened, it should be able to be slipped of the camshaft in the cylinder head.Step 4: Remove the head bolts. Every engine will have its own procedures for the order that the head bolts are removed or tightened.
        Loosen head bolts ΒΌ turn each in the order specified, which may require a special socket. Once all the bolts have been loosened they may be removed one at a time. The bolts must be organized or marked in case they are different lengths.
        Step 5: Remove the cylinder head. Once all the bolts are removed, the cylinder head may be removed from the engine. If it is stuck, tap lightly on the side of the head with a rubber hammer to loosen the cylinder head.
        • Warning: Most head bolts are torque-to-yield. These head bolts are single use only and once removed must be replaced. Torque-to-yield head bolts stretch when they are torqued to allow them to tighten properly and repeated application can cause the head bolt to break.
        Removing the head bolts can seem like a daunting process
Sep 29, 2016 | Cars & Trucks
What parts have to be removed to change output speedsensor on 97 sebring convertible jxi?
Hi Nicholas, Im AL the owner of Big As Auto Repair.
FRONT WHEEL SPEED SENSOR
REMOVE
  1. Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting in the Lubrication and Maintenance section of this manual, for the required lifting procedure to be used for this vehicle.
  2. Remove the tire and wheel assembly from the vehicle.
  3. Remove the speed sensor cable routing bracket Speed Sensor Cable Routing Brackets from the steering knuckle. Remove the wiring harness sealing grommet retainer and speed sensor routing bracket from the inner fender.
  4. Remove speed sensor sealing grommet from the inner fender Wheel Speed Sensor Connection To Vehicle Wiring Harness Then unplug the speed sensor cable from the vehicle wiring harness Wheel Speed Sensor Connection To Vehicle Wiring Harness
  5. Remove bolt Speed Sensor Head Attachment To Steering Knuckle attaching the speed sensor head to the steering knuckle. Then remove speed sensor head from steering knuckle. CAUTION: If speed sensor head locating pin has seized to the steering knuckle, do not attempt to remove speed sensor head by grasping with pliers and turning. This will damage the speed sensor head. Use only the following procedure.
  6. If speed sensor head can not be removed from steering knuckle by hand, the locating pin on the speed sensor head has seized to the steering knuckle do to corrosion. Remove speed sensor head from steering knuckle using the following procedure. Remove disc brake caliper from steering knuckle, and remove brake rotor from hub/bearing assembly. Then insert a pin punch through hole in front steering knuckle Speed Sensor Head Removal From Steering Knuckle and tap speed sensor head locating pin out of steering knuckle.
Hope this helps and please visit my auto-repair-website at:
http://www.bigasautorepair.com/
Oct 08, 2015 | Cars & Trucks
How to change head gasket
That's a pretty big job, if you're not a mechanic.
in general (I've not done one on an Aveo)
1. detach intake and exhaust manifolds from head
2. remove sparkplugs and move all wiring aside
3. Remove cover from top
4. Guessing overhead cams, remove belt/chain
5. remove head bolts.
6. pull head. I used to have a special tool that threaded into plug holes and pressed down on head studs. Otherwise, we'd end up lifting the whole car by the head and beating on it to get the head off.
7. clean gasket debris off head and block.
8. If needed send head out to be milled to flat.
9. place head gasket, add head, and torque to specs.
and the rest of what you did to get it off, in reverse order.
Jun 09, 2015 | Chevrolet 2004 Chevrolet Aveo
How do I remove heads on a madza mpv
Drain the coolant, remove the exhaust pipe(s) from the exhaust manifolds, remove heater hoses from heads, remove, rocker covers from the heads,remove cam belt covers and cam belt, undo the head bolts, and remove heads, this is a short version of removing the heads, but I got the feeling this job might be a little big, if you don't know for sure what you doing. special if it has to go back together as well.
Dec 01, 2014 | Mazda MPV Cars & Trucks
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
I am trying to remove and reinstall the cylinder head of my 1994 S 10 pickup truck. I have removed the nuts and bolts holding the intake and exhaust manifolds to the head but I am having some dificulty in...
Leave the exhaust manifold attached and just push it away. Remove the head bolts and make sure all vacuum lines and fuel lines and water lines are disconnected. Make sure you have the head resurfaced before reinstalling and buy new head bolts. Remember to torque the head bolts to spec. But it seems to me like you pretty much got the hang of it.
Jan 30, 2011 | 1994 Chevrolet S-10
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
How to replace head gasket 1998 Lumina
Cylinder Head Removal & Installation 3.1L Engine To Remove:
NOTE: With some minor variations, this procedure can be used on both the left and right cylinder heads.
  1. Raise and safely support the vehicle.
  2. Drain the engine coolant and the engine oil. Lower the vehicle.
  3. Remove the upper and lower intake manifolds.
  4. Remove the rocker arms and pushrods.
  5. Remove the exhaust crossover pipe.
  6. Remove the engine mount strut bracket.
  7. If removing the left side (front) head, remove the dipstick tube.
  8. Tag for identification, then remove the spark plug wires.
  9. Remove the spark plugs.
  10. Remove the exhaust manifold using the procedures found in this section.
  11. Remove the eight cylinder head bolts, then remove the cylinder head. There are locator pins that align the head to the block. Pull upwards on the head to disengage the pins, then remove the cylinder head to a suitable work area.
  12. If the head is be overhauled, remove any remaining components such as the engine lift hook, the fuel line bracket bolts, the engine coolant temperature sensor, etc., as required.
Position a new gasket, install the head, then tighten the bolts in the sequence shown (3.1L engine shown) 93173g43.gif
To Install:
NOTE: If the head gasket failed, determine the cause. Gasket failure is caused by the following conditions: improper installation; overheating due to a failure in the electric cooling fan system or a leak in the cooling system; loose or warped cylinder head; missing, off location or not fully seated locator dowel pins; low torque on the cylinder head bolts; warped block surface; scratched or gouged gasket surfaces; excessive intake manifold torque and even cracked engine block tapped holes.
  1. Clean all parts well. Remove all foreign material to the bare metal. Do not use a motorized wire brush on any gasket sealing surface. It is good practice to use the proper size thread-cutting tap to clean the threaded bolt holes in the block. This helps assure an accurate torque reading.
  2. Place a new head gasket on the clean engine block deck surface. Many gaskets will have some sort of marking denoting TOP or THIS SIDE UP. Make sure the gasket sits flat and is not hung up on the locator dowel pins. Use no sealer on the head gasket.
  3. Carefully set the cylinder head in place, using care not to damage the gasket. Make certain that the head engages the locator dowel pins that properly position the head.
  4. The bolts should be very clean since dirt built-up on the bolt threads makes it difficult to get an accurate torque reading. These are 'torque to yield' bolts which stretch a small amount when tightened; new bolts are always recommended. On a used vehicle, especially a high-mileage vehicle, it may be difficult to determine if the heads have been removed before and how many cycles the bolts have been removed and tightened. New bolts should be part of any cylinder head service. Use GM Sealer #1052080, or equivalent, on the threads of the head bolts and install all eight bolts, finger-tight.
  5. With an accurate torque wrench, tighten the bolts gradually, in sequence, working from the center outwards. Final torque should be 33 ft. lbs. (45 Nm), plus an additional 90 degrees (1/4-turn). A torque angle meter is recommended.
  6. Install the remaining components in the reverse order of the removal process.
Aug 11, 2010 | 1998 Chevrolet Lumina
Torque specification on a 2003 alero cylinder heads 3.4 liter
3.4L Engine To Remove:
  1. Remove the lower intake manifold.
  2. Remove the exhaust crossover pipe.
  3. If removing the right cylinder head, remove the catalytic converter from exhaust manifold.
  4. If removing the left cylinder head, remove the engine oil dipstick and tube.
  5. Remove the rocker arms and pushrods.
  6. Remove and discard the cylinder head bolts.
  7. Remove the cylinder head.
  8. Clean the mating surfaces on the following items:
    • Cylinder head
    • Cylinder block
    • Intake manifold
  9. Clean the cylinder block bolt threads.
NOTE: During disassembly, keep the valve train components together for proper location during assembly.
To Install:
NOTE: Coat the cylinder head bolt threads using thread sealer.
  1. If removed, install the following components:
    • Exhaust manifold
    • Accessory studs
    • Spark plugs
  2. Place the cylinder head gasket in position over the dowel pins. Ensure that the THIS SIDE UP note is showing.
  3. Install the cylinder head. Cylinder head torque sequence ’99-‘00 gmpc_v6_14.gif
  4. Install the new cylinder head bolts.
    • Tighten the cylinder head bolts a first pass to 44 ft lb (60 Nm).
  5. Tighten the cylinder head bolts in sequence an additional 95 degrees.
  6. Install the intake gasket.
  7. Install the pushrods and rocker arms.
  8. Raise and support the vehicle.
  9. Install the catalytic converter and dipstick tube and indicator if removed.
  10. Lower the vehicle.
  11. Install the exhaust crossover pipe.
  12. Install the intake manifolds.
  13. Connect negative battery cable.
  14. Fill the cooling system.
Jul 03, 2010 | 2003 Oldsmobile Alero
I have I think a cracked head on my 2003 kia sorento I'm trying to find a brochure or diagram on how to disassmble a head
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Disconnect the negative battery cable.
  5. Disconnect the upper radiator hose.
  6. Remove the breather hose and air-intake hose.
  7. Remove the vacuum hose, fuel hose and coolant hose.
  8. Remove the intake manifold.
  9. Remove the cables from the spark plugs. The cables should be removed holding the boot portion.
  10. Remove the ignition coil.
  11. Remove the upper and lower timing belt cover.
  12. Remove the timing belt and camshaft sprockets.
  13. Remove the heat protector and exhaust manifold assembly.
  14. Remove the coolant pump pulley and head cover.
  15. Remove the intake and exhaust camshaft.
NOTE Keep all valvetrain components in order for assembly.
  1. Remove the cylinder head assembly. The cylinder head bolts should be removed using the 12 mm socket, in two or three steps. Clean the gasket pieces from the cylinder block top surface and cylinder bottom surface.
Cylinder head and related components
Cylinder head bolt torque sequence
To install:
  1. Verify the identification marks on the cylinder head gasket. Install the gasket so that the surface of the cylinder head identification mark faces toward the cylinder head.
  2. Install the cylinder heads with new gaskets. Do not apply sealant to these surfaces.
  3. Tighten the bolts in sequence to 75–82 ft. lbs. (105–115 Nm).
  4. Installation is the reverse of the removal procedure.
Oct 26, 2009 | 2003 Kia Sorento
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
