Question about Electronics - Others
Inverter problems Freezer not getting cold n refrigrator
  • 86 Answers
SOURCE: refrigrator stopped working
Morning, This seems quite a easy problem to fix.! Check to see if the f/.freezer has to compressors (motors)? If so the you find that is more than likely to be that the fridge thermostat has broken. A very easy way of checking if you electrially minded is to remove the thermostat from the housing a connect the live and common wires together and switch on, It then should switch on if there is no other problems, Then just replace the stat.
Good luck......
Posted on Dec 29, 2008
wheelshot
  • 102 Answers
SOURCE: Maytag RSW2700 Freezer cold Refrigrator Warm
Check for excessive frost build up in the freezer on the back panel. This would indicate that you have a defrost problem. One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, measures open (bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Posted on Apr 11, 2009
  • 245 Answers
SOURCE: Need help on freezer build up and freezer not getting cold
try defrosting it manually. unplug it and let it sit with the doors open for about 4-5 hours and make sure the doors close and seal all the way.
Posted on May 22, 2009
  • 942 Answers
SOURCE: the freezer is cold but inside refrigrator is not cool.
Hi...
In this problem you need to check this following:
  • Check the temperature settings
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Good luck
Regards
PCmania
Posted on Jul 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: freezer is not working
Your defrost system has gone out on this unit. This is a simple repair and if you'll give us a call, we'll be sure to get the right part out to you real soon. We look forward to hearing from you real soon.
Posted on Oct 10, 2009
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Freezer of the refrigrator is not freezing. Norge,
sounds like the cold coil is freezing up and this is a defrost problem.. ck the defrost themo/ and the heater . / may also be the defrost timer . but every 3 mo ( i would think the defrost terminator is failing .. ) mm
Aug 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer and refrigrator both not cold as supposed to be
make sure the compressor is working first,if not then replace the ptc overload on the compressor,if you have had lights blow out in the refrigerator section and theres a chattering/clicking sound in the rear and the new lights strobe dimly and the digital temp read-outs are dark,then its the main board in the rear thats bad
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, but the coolers not cold enough?
The fan in the freezer blows the air through the vent and it returns to the freezer through another vent at the bottom. Make sure both are clear and open.
Jan 10, 2010 | Refrigerators
Freezer is not working
Oct 09, 2009 | Refrigerators
Refridgerator and freezer are not cold
hello sir/mam
if this is the problem please check the condensor of the refrigerator for its enough refrigrant.
Sep 14, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
May 22, 2009 | Zanussi ZEBF250W Bottom Freezer...
Refrigrator stopped working
Good luck......
Dec 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Electronics - Others Logo
64 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
