Question about Comfort Zone Heating & Cooling
Pull string oncomfort zone quartz infrared heater broke
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
SOURCE: string broke on marvin 7260 light
If you've reached this web site, you've probably also discovered that the W.B. Marvin company web site informs that they are no longer in business.
I have a Marvin 7260 Ceiling Mount radiant heater, without light, and just had my pull string break as I gently tugged on it to warm my shop.
As I stood there with the the string dangling in my hand, staring dumbfounded at the unit hanging from the ceiling, I realized that I've been using this heater for quite some time and never paid attention to where the string was attached...
I dismounted the heater from the ceiling, poured a cup of coffee, and began a stare down with my old friend. That's when I remembered that I bought two and one was still packed away in the box.
Be sure the heater is cold enough to handle, unplug the heater and dismount from the ceiling, where applicable.
If you're like me and don't remember where the string was attached, it is attached on the side of the unit which has the temperature setting gauge bars.
Adjust the hanging bracket so that you see and access the two screws holding the side panel on the heater. Be sure the screws are fully loosened and pull the side panel from the heater (Note: the hanging bracket may limit how far you can remove this panel).
Peek inside and you should be able to see the other end of the string attached to a tab next to the temperature setting bar gauge. If it was a clean break and there is no string on the inside, you should be able to see a shiny metal tab with a hole in it mounted behind the plastic temperature bar knob.
Decide whether you are going to upgrade your string or reuse the existing one. Thread it through the hole on the front grill immediately in front of the gauge and then through the hole on the shiny metal tab and tie a knot.
Reassemble the side panel to the heater with the two screws - Be sure that you do not tighten these screws too tightly as you are screwing into light aluminum which can be easily stripped - snug is good enough. Plug the heater in and test it. If all works well - remount and enjoy the radiant heat.
Keep in Mind: These heaters cost me $29.99 at Home Depot and therefore are not necessarily worth investing a lot of money or time in repairing. This pull string repair is quite simple however it would be quite reasonable to simply replace the heater if something serious were wrong with such.
Now...Pour yourself a cup of coffee and get that look off your face...!
Best of Luck,
Steve
LaGrange, GA
Posted on Dec 16, 2008
emissionwiz
  • 80339 Answers
SOURCE: I have an AO5 error
what is A05
Posted on Sep 10, 2010
  • 4736 Answers
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
I have a quartz infrared zone heater and I need to know how to reset from celsius to regular heat
There you go
OPERATION INSTRUCTIONS
FUNCTION
POWER
The POWER button supplies power to all the functions of
the heater. Pressing the POWER button again the heater will
be put in standby mode.
Pressing and holding the POWER button on the control
panel for 3 seconds will switch between °F and °C.
Dec 25, 2017 | Heating & Cooling
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Comfort Zone Infrared Quartz Heater is not staying on it cut right off. Please advise
Clean the filter and the element. Make sure that they are dry before you re-install them. Check the power cord and socket for damage..
Feb 21, 2015 | Comfort Zone Heating & Cooling
Comfort zone heater
If its to close to the wall it can shut off due to high temp
Feb 25, 2014 | Heating & Cooling
Heat but no fan
Temperature fan switch needs replacing...make sure there is power to it.
Dec 17, 2013 | Comfort Zone Infrared Quartz Heater
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
My Cz2011 Comfort Zone Infrared heater will not stay on. It will stay on for maybe one minute and then it shuts off
I had same problem with mine and found out that the timer was turned on make sure your timer time is set to 00 hope this helps
Jan 01, 2013 | Comfort Zone Infrared Quartz Heater
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Jan 18, 2011 | Comfort Zone Heating & Cooling
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
String broke on marvin 7260 light
Best of Luck,
Steve
LaGrange, GA
Oct 25, 2007 | Marvin W.B. 7260 Quartz Heat N Light...
Heating & Cooling Logo
98 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
