Question about Radio Communications
Cb radio troubleshooting
When I key up, dome lite comes on and other electrical problems acure. dx95t big rig on a peterbilt 387.
2 Suggested Answers
  • 1274 Answers
SOURCE: want to know how to prevent feed back in my cb
Hi kyle,
Welcome to FixYa.
My name is John. I will be assisting you with you issue. The first thing you can do is reposition it in a different location, away from speakers, wires, am antenna coax,etc.
If you have more issues, let me know.
Thanks for using FixYa. Happy Holidays......John
Posted on Dec 27, 2010
Can't find fuse for cb radio on a 2006 387 peterbilt
if you are going to hook it up directly because its your truck then you need to find the fuse panel. In there should be the fuse or circuit breaker you need.there should also be two connectors on your dash,one pos and the other neg. then there is the trusty old cigarette light plug.those are your options.
May 02, 2014 | Radio Communications
No front panel illumination
is your dimmer switch turned on or off.
Feb 07, 2013 | Galaxy Radios DX-95T Base CB Radio
Will a cobra power mic cure the low mod on my cobra 19 dx iv eu or will it blow the front of the rig
that is simply bs, Ham radio shops rarely like CB people (I am a long time cber and also a ham.
On that radio there are two things you can do, look for the mod limiter and remove it or another more simple thing:
This radio comes with a 1000 ohm element in the mic--like speakers---Get a older or new 500 ohm microphone and wire it or have it wired for the 19 dx, it will make a big difference in how it sounds.
I not only worked on those radios but sold them in a shop I owned.
You might find a used mic that's 500 ohm, it is usually stamped into the back case of a mic.
Dec 19, 2012 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
Want to know how to prevent feed back in my cb radio in my 387 peterbilt
Hi kyle,
Welcome to FixYa.
Dec 27, 2010 | Cobra 29 LTD CB Radio
How to replace cb coax peterbilt model 335
take the old out pay good attention to the way it comes out so you can put new back in
Dec 22, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a Galaxy 99 and I just swapped companies and I now drive a Peterbilt 387. When I plugged my CB in it tripped the fuse. I replaced the fuse behind the glovebox and CB still doesn't work so I am...
The Galaxy DX959 radio requires 12volt DC power. There should be a plastic fuseholder in the power cable near the radio end. There are no fuses inside the radio.
Ascertain that the radio has been connected up with the positive and negative the correct way around before replacing the fuse. Do not bypass the fuseholder or use a fuse with a rating larger than the origianal fuse.
If you have connected the radio to 24volt truck power instead of 12volt power even once you will probably need to send the radio to a competent technician for repair or buy a new radio.
Dec 10, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
I am looking to buy either a dx48t or dx95t
both are hi powered,approx 140 to 150 watts, radios that need about 14 amps of power to be safe,watts divided by volts=amps needed.if you want to plug and talk i suggest something 80 watts or less.
Oct 04, 2009 | Galaxy Radios DX-95T Base CB Radio
My panasonic has new final and driver but still does not transmit
thankyou for assistance but rand to dollar is to much to come by/greetings Henry
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra NW LTD CB radio
start out by getting a good antenna like a wilson or k-40 if your using it on a big rig make sure its a metal mirror and door a lot of big rigs use fiberglass and thats a nono you must get a no ground plane antenna...its all in the antenna...good luck doc's cb shop ny
Apr 09, 2008 | Cobra 29 NW CB Radio
Radio Communications Logo
172 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
