Question about Whirlpool Refrigerators
Refrigerator not cold
I have a Whirlpool model GB2FHDXWB01 and it isn't getting cold. About a week ago everything was super cold, and now it won't get cold enough. The freezer seems to be okay.
SOURCE: Refrigerator and freezer not getting cold enough
I had this problem last year. I unplugged the the refrigerator and plugged it in an hour later it worked for a little while then quit over night. I finally called a sears repair they came 2 weeks later it was the motherboard, could have fixed it myself, what a hassle. Thankfully I have a fridge in the basement. Still this is a do it yourself.
Posted on Nov 17, 2008
  • 291 Answers
SOURCE: Maytag freezer & refrigerator not coold enough
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. I feel heat/warmth on the front edge of my refrigerator....why?
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Posted on Apr 03, 2009
buddymcl777
  • 67 Answers
SOURCE: Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
Posted on May 09, 2009
SOURCE: My freezer is okay but my refrigerator is not cold really.
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
  • 3 Answers
SOURCE: the refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
Posted on May 21, 2009
How to fix loose freezer handle on whirlpool refrigerator
This repair is not as easy as you might expect. The door gasket, inner door panel, and insulation must be removed to get at the screws attaching the door handle.
Oct 05, 2014 | Whirlpool Refrigerators
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Manuel for Whirlpool GB2FHDXWB01
I found the manual for the Whirlpool GB2FHDXWB01 refrigerator on Manage My Life, http://www.managemylife.com/mmh/owner_manuals/2258/WHIRLPOOL-Bottom-Mount-Refrigerator-L0910025?brand_name_search=GB2FHDXWB01+WHIRLPOOL . The direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0910025.pdf .
Unfortunately, I don't see anything about removing the baskets in this manual. Whirlpool also has the manual here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf . The parts list is at https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10304507.pdf .
You will need Adobe Reader or a similar program to access the files.
I hope this helps.
Apr 04, 2013 | Refrigerators
Whirlpool GB2FHDXWB01 just started getting way too cold in the freezer. Ice cream is rock hard, seems to run all the time.
Most likely its the cold control located in the fresh food section...unless you have a dual cold control....
Oct 03, 2012 | Whirlpool Refrigerators
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
I have a whirlpool refrigerator and the refrigerator section is not getting cold enough. A couple of weeks ago, we found ice shavings and icecicles forming from the vent on the inside. Ever since then it...
I suggest if you can empty the refrigerator of all stuff and open it completely long enough for everything to defrost inside it. Using a fan to blow inside it will aid the process making it quicker. Then restart it and see if it cools ok. If you have an automatic defrost unit then maybe the defrost unit is not working correctly...the control timer for it can be bad or the heating elements that do the defrost can be burned out...believe it or not the refrigertor has heaters inside the door etc. which turn on periodically to do the defrosting.
Aug 22, 2009 | Whirlpool Refrigerators
Hi I have a whirlpool fridge the buttom don't stay cold an
This is most likely the defrost timer or Adaptive defrost system. I will need your model number to be able to tell you what your model has. The places to locate the model numbers are in the photo be.if a Sears model the numbers will look like this for example 512.3645897
Thanks, and let me know, Sea Breeze
Or just click
HERE
and enter your model number.
Aug 06, 2009 | Refrigerators
Turns off won't turn back on unless you move thermostat
Sounds like a defective cold control ( off/on thermostat).
They will tend to stick in the off position. Your moving the knod unsticks it.
May 24, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerators Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
