Question about Sylvania Televison & Video
Sylvania mosaic flex light will not work
Newly purchased item will not turn on
Audio for the sylvania smartbook synet07526 is not working?
Go in to Device Manager under Control Panel ' Administrative Tools ' Computer Management and see if there is a yellow bang next to the sound card. If so, try reinstalling the driver. If this does not solve the problem there may be a problem with the connector.
If there is not a yellow band next to the sound card, there could be a Windows setting that has the volume turned all the way down.
Or, try connecting head phones to the headphone ports to see if you hear sounds.
Aug 17, 2014 | Computers & Internet
Samsung HL-S5687W HDTV. TV turns on for a few seconds then turns off. No lights on the front blinking but it did make a whirring sound when it was turned on then went off. Could it be the color wh
Horizontal scan output section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | Sylvania SRT2232S 32" TV
Sylvania HD1Z DV-5000 Camcorder won't power up
Sounds like the battery is faulty, or is not charging properly. Can you remove the battery and try it on another (heavy load) device? At least check with a voltmeter and put a (say) torch/car bulb across the contacts
Jan 31, 2014 | Sylvania HD1Z Camcorder
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
Touch screen not working
Hi, The problem with your phone is as a result of a bad flex connector cable which connects the touch screen to the panel,it's weak and needs to be replaced.
However,the solution is to take apart the phone and remove the flex cable which is in form of a ribbon situated behind the touch screen and replace it with a newly purchased flex cable.
Thanks and take care
Aug 02, 2010 | Samsung Star GT-S5233 Cell Phone
MY Sylvania LC321ss9 TV just shut off today!
It means your power supply went out. I had a sony with the same symptons and it cost 140 to fix it.
May 13, 2010 | Sylvania LC320SS9 32 in. LCD TV
REMOTE DOES NOT WORK ON SYLVANIA TV
well, i got a one for all remote from a wal mart or some where else, and i have a sylvania tv. it works for my tv. might want to look into that. www.oneforall.com
May 27, 2009 | Sylvania Televison & Video
Tv screen is normal, then green then off. Please help
It can be one of two items. The green output transistor or the green cathode has developed a short.
Jan 10, 2009 | Sylvania Televison & Video
Televison & Video Logo
61 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
