Question about Canon imageRUNNER 1210 Copier
SYSTEM EROR 245
HOW CAN I FIND THE COUNTER PCB?
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: eror 355 how i can resolve.
Enter service mode(additional funcation # ) then scroll down to item 12 ( clear ) and press the set key then scroll to ERR and press the SET key twice then the display should display Clear OK and it should return to the stand by mode. And that is it. Done
Posted on Feb 11, 2008
E-245-0013 in canon ir6000
check the counter pcb on the main controller. if the main controller was replaced the original counter pcb MUST be installed on the new main controller. The counter pcb is married to a machine as soon as its powered on and CANNOT be installed on another copier.
Feb 19, 2015 | Canon Office Equipment & Supplies
Canon ir 8500 eror code e0732 000
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Check connection between reader assy to main unit
Jul 18, 2014 | Canon Office Equipment & Supplies
CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING POWER SUPPLY BOARD STIL COULD NOT WORK UNTIL I HAD TO REPLACE MAIN BOARD THEN IT CAME ON BUT WITH ERR CODE 354 I HAVE TRYED TO CLEAR IT ALL IN VAIN
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Jun 28, 2011 | Canon iR 2016i Black and White Copier
Canon ir 2200 error e246-0002
An E246 is a Counter pcb issue. You may want to reseat the Counter pcb on the Main Controller, Also if you swapped the Main Controller you need to leave the orginal Counter pcb in the machine. If this doesn't pan out you need to call the TSC and open a ticket. You can not order a Counter PCB.
Mar 09, 2011 | Office Equipment & Supplies
IR 1210 Error cod E245
how to reset the system Err E245 in canon Ir 1210
Jul 20, 2010 | Canon imageRUNNER 1210 Copier
I have a 02 BMW 525i with check engine light on..Code 243, 246, and 245..What could be the problem? How do I fix it?
Lots of specific BMW forums on the net and am sure if you Google the eror codes you will get an explanation.
Mar 10, 2010 | BMW 525 Cars & Trucks
E245 for ir1630
E-245 is for the defective counter pcb. the board is a small one on the main controller that keeps track of the amount of copies the machine has made. this code is normaly seen when someone changes the main board and forgets to switch the counter pcb. it is possible that there is a loose screw on the board.
Jul 31, 2009 | Canon imageRUNNER 1630 Copier
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Eror 355 how i can resolve.
Feb 09, 2008 | Canon ImageRUNNER 1670F Copier
Canon imageRUNNER 1210 Copier Logo
15 people viewed this question
old marine
old marine
