Question about Locks & Locksmithing
Electronic safe manual
Someone pried my safe open now i cant close it
5 Suggested Answers
SOURCE: sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Posted on Sep 07, 2008
  • 461 Answers
SOURCE: cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Posted on Jan 03, 2009
  • 219 Answers
SOURCE: my bmw 2000 528i left rear door did not response
it sounds like the lock actuator inside the door has frozen. if that is the case, you will have to remove the inner door panel partially or fully to gain access to the actuator.if you press down on the door lock knob, does it move down.if not I would definitely suspect a failed actuator.
Posted on Mar 21, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
Richmond electronic digital safe
I no longer have the manual and cant remember my code so how do i get the safe open ? Help please !!!
Jul 04, 2013 | Locks & Locksmithing
I cant open, this box is lelong to my mum she pass away and I nee help to open
I think that this is what you are looking for...
How to open electronic safe
http://www.ehow.com/how_4480775_open-electronic-safe.html
heatman101
Feb 06, 2011 | Safe International Digital Electronic Safe...
I have a gordon elect. digital safe with out key. #P45891 it is closed and i forgot code how do i open it?
OK DRILL A 1/4 INCH HOLE TO THE RIGHT OF THE KEY,LOCK ASSEMBLY JUST A TAD BIT BELOW CENTER OF THE SAFE KEY LOCK, NOW USE A SCREWDRIVER AND STICK IT IN THE HOLE, GIVE IT A FEW SACKS WITH THE PALM OF YOUR HAND . NOW WITH THE SCREWDRIVER STUCK IN THE HOLE TIP OF THE SCREWDRIVER TOWARDS THE LOCK ASSY LIGHTLY PRY TO THE LEFT AND DROP THE SAFE ON THE GROUND, (JUST LIKE THE ONE IN THE PICTURE)THIS WILL JAR THE ELECTRIC SOLENOID .YOU MUST DO BOTH AT ONCE. IT MAY A FEW TIMES..IF THAT FAILS TAKE YOUR HARBOR FREIGHT GRINDER WITH A CUT OFF BLADE AND SCORE THE DOOR IN THE CENTER FROM TOP TO BOTTOM, (DON'T CUT THREW OR IT WILL BURN UP ALL OF YOUR STUFF !) USE A LARGE SCREWDRIVER TO THEN PRY THE CENTER OF THE SAFE DOOR UP.. ITS A JUNKY SAFE, BUT THAT'S A GOOD THING 4 U . GOOD LUCK AND IF'N I WAS OF HELP COMMENT VOTE (TELL ME SO I CAN BRAG ON HOW DERN GOOD I'AM).. CUZ IF I CAN;T FIX IT I'LL BREAK IT TRY'N.. Jay longwood Fl
Jan 30, 2011 | Safe International Digital Electronic Safe...
I forgot my safes password
call a local locksmith he can help, if it can not be opened you may have to bust it open, call some one with many tools they may help. I recommend an angle grinder this will cut through steel. If you can remember where the pins are that hold the door closed you can grind through the side and cut the pins with two cuts. would take ten minutes to open with this method. There is probably an upper and lower pin.
Apr 01, 2010 | Safe International Digital Electronic Safe...
Trunk lid will not close - either electronically
Once a close fails, the latch may be now in the closed position, preventing a second try.
So release it first.
You should see the latch open up, so that it can accept the locking pin once again.
Then try closing it again.
If you have pounded on it, it may be hard to get it to release now, so you may have to pry on it with a screwdriver.
Feb 22, 2010 | 1992 Cadillac DeVille
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
270 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
