Question about Golds Gym Trainer 410 Treadmill
The power is on but the console doesnt come up. i took off the top to see in the panel but i dont see any wires out of place .. could it be the motor?
    New Friend:
When I hit go there is 2 lines on screen . I reset but nothing and had to order a new safety key which cam in today and fits. It's the round key and the other end gas a plastic square does that go somewhere . At this point will do nothing . It worked a few months ago then my son or friends must of taken key now won't do anything.... please help I'm katharine
Posted on Jul 17, 2015
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
If the buttons do not beep when pressed you may have a console problem. Otherwise I need more info to determine whats wrong.
Posted on Jan 04, 2014
  • Katharine Smith Jul 17, 2015
    They do not beep nothing on screen.is the console where all buttons are or is it the memory board? I looked at that all seems to be in place and tight
How to remove and put front panel on
see this causes and fix it. Replacing the control b. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Sep 27, 2012 | Washing Machines
Problems with grando 0 go sf 262 washing machine
see this and fix it. God bless you
Control
Sep 27, 2012 | Candy Washing Machines
I switch the ps3 on and it switches it self straight off
ok i think this will work turn your ps3 on by holding the power button an dont stop pushing it until it beeps twice on the second beep let go and it should take you to the override screen and once there hit reset settings to default if that doesnt work than take the top of the ps3 off anr there is a silver box in the upright left corner of the system make sher all wires are securley plugged in
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
Game is scatched took to place to fix it steel dont work
If all of your other games work, take it back and tell them it does not work, it may never work...good luck.
Apr 04, 2010 | Microsoft Xbox Console
No power after detergent dispenser replacement
check the terminal block. thats where the power goes to the machine.could be a short ot burnt wires.
Mar 06, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
How to place indicator led cables to motherboard
hey look close to the nearby processorin motherboard there is 9 pin (depends on motherboard) for power and for reset button... close your eyes to motherboard at that place you will find also the name which are mention in motherboard e.g. power and reset in motherboard just plug red wire in power and and green for reset ( depends on motherboard) you an chk manually ...
Apr 05, 2009 | Computers & Internet
My Nintendo DS lite doesnt turn on
Maybe the baterry doesnt work you could try to buy a new one because at somepoint batteries dont work anymore that happened to me.
Jan 16, 2009 | Nintendo DS Lite Console
Original xbox power problem
A common problem caused by corroded traces on the motherboard.
Easy to fix with a few jumper wires.
Info here -> http://forums.llamma.com/viewtopic.php?t=12329
Nov 04, 2008 | Microsoft Xbox Console
Whirlpool wtw5850sw0
look over the top of the control panel look straight down you see 2 phillips head screws on either side youll need to remove, the console will flip back giving you access to the switch..just for curiosity its not "clicking" when you close the lid therefore it fills and stops, doesnt spin or drain???? try this first.open the lid all the way, the left side hinge acts as the plunger for the switch.. feel under there open and close lid a little to help find the metal hinge. after finding the hinge place a 1/4 nutdriver(doesnt matter the size just needs a hollow shaft.) over the protruding portion of the hinge. still under the top but right there! when its on push the driver back(in essence bending hte armature back slightly). itll flex a bit as you push the hinge the door will push back(you got the right spot then). after you crank it back a bit try closing the lid now. did you hear it click??? your golden!!!!!!! no need to change.. reason for telling you this is for the most part the switch doesnt go bad but the lid /hinge isnt bent enough to make contact, and over time of swinging top into the fully opened position it actually bends to far forward to make contact. i have a box full of switched that other techs ordered and weren't needed. not saying they dont go bad ive seen that, but try this first might get lucky!!!!
Mar 16, 2008 | Whirlpool LSR9434PT Top Load Washer
Golds Gym Trainer 410 Treadmill Logo
614 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
