Question about HP Office Equipment & Supplies
Unable to get Printer cartridges to work on HP6313
I have bought several new cartridges for my HP6313. Each time I replace them the machine tells me that the cartridges are not for this machine, I have HP336 HP342 HP 343 HP 342 as I am not sure which cartridges are the replacements for HP 129 and HP 135. Please can someone help me
  • rosteedman May 21, 2009
    Thank you so much for your help!
    Rozanne
    Scholar:
  • 70 Answers
Model names in the HP Brands can sometimes be similar and confusing because of the prefix or series attached to them.
Consult your manual for the required toner cartridges
When purchasing the replacement, go along with the finsihed set in order to help you identify them at the shop
Also you can try the HP 343 or 348 Tri Color, HP 339, 336, 337 Hi capacity black
Honestly i would advise taking the finished set of toner cartridge to the store and purchase the same model.
Laslty take out the toner and look behind it or at the side. Theres a unique code or number inscribed on it. that would help you to get the toners that are compatible with your printer
Posted on May 21, 2009
  • Onyebuchim Obike
    Onyebuchim Obike May 21, 2009
    Thanks for stopping by.
    Let me know if you still need help
My new Lexmark Interpret S405 says there is no cartridge in the Magenta slot but really is and it is in there correctly 'cause it can't go any other way. Help!!!
Go into your printer settings and tell the printer to use black ink only and see if it works. You may have got a start up cartridge with the printer and it will not print that many copies and the manuf. now have a chip in the ink replacements that will not allow you to remove and refill the ink so when you take it out the printer won't recognize the cartridge the second time.
May 21, 2017 | Lexmark Office Equipment & Supplies
I just installed a new black ink cartridge for the Lexmark X125, but now the message reads ADD CARTRIDGE. I have tried re-installing it several times. I have also wiped the metal connectors. I have...
Check if the new cartridge installed is compatible with the printer. If it is compactible then make sure that you properly position the cartridge of the printer. It will surely works perfectly. If you encounter any problem during the process contact me on greatengineerid@hotmail.com or call +234-8023821869
Cheers.
Engr. Adewumi I.O
Sep 05, 2011 | Office Equipment & Supplies
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges...
My hp 7410 printer says ''remove and check cartridge on right'' I did this several times and even bought a new one'' I does not work. I tried cleaning it, it does not work. I have always used HP cartridges for the printer which is over a year old. How can I fix this problem?
Jul 11, 2009 | HP Office Equipment & Supplies
Cant print
Ink button on? Check status monitor? I think is ink out message. Head cleaning for several time, throw ink too much. If u don't use CISS, after instaled ink tank, just wait for 1 hour before use printer. Ink will flow to head itself.
Jun 12, 2009 | Epson Stylus C43UX InkJet Printer
Cartridge problems Epson 4000
Where are you located? is it Humid? possibly the chips on the cartriges have something on them (corrosinon, oil from a finger touching the chip, etc) that is interferring with good contact with the wire "feelers" inside the machine. clean the chip with Qtip and alcohol, or fine fiberglasss bristle battery contaact cleaner (hard to find these days)
May 13, 2009 | Epson Stylus Pro 4000 InkJet Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
79 people viewed this question
Seeker5211
Seeker5211
