Question about Ricoh Aficio 2045e 2035e Copier Postscript3 Type 2045
SRAM problem of copier printer - Ricoh Aficio 2045e 2035e Copier Postscript3 Type 2045
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
How repar this problem u2 - 23 sharp arm - 451 u
SRAM memory individual data check
sum error (ICU)
Check sum error for every data in the
SRAM memory of the MFPC section
(Communication management table,
sender registration data, etcSRAM trouble
Control circuit runaway due to noises
ICU PWB SRAM access circuit trouble
.)Automatically initialize the data related
to the check sum error by turning OFF/
ON the power.
Since the registered data are deleted,
register the data again.
Use SIM16 to cancel U2 trouble.
Replace the ICU PWB.
Mar 12, 2015 | Sharp Office Equipment & Supplies
How to stop smiley face and *** printing constantly
Clear the DRAM and SRAM memory. Doing so will remove all setting convert back to default setting. DOCUMENT
Feb 07, 2014 | Minolta QMS PagePro 9100 Laser Printer
F14 erroe code
F14 indicates Invalid backup counter.
Download the counter value of the MAIN board to the SRAM board in
the setting mode (08-388)
Feb 12, 2012 | Toshiba E-Studio167 Copier
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
CODE U2-23 sharp please tell what is the problem ? thanks
SRAM trouble or
P<interupt> C <interupt> 1 6 Start
Jan 11, 2010 | Sharp AR-M455N Copier
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Sram error missing E
Better if you have other person to help you.
Turn off the printer, hold 0 3 5 6 7 buttons, turn on the printer, wait until the *s disapair.
Jun 07, 2007 | Xerox Phaser 7300DN Laser Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Ricoh Aficio 2045e 2035e Copier Postscript3 Type 2045 Logo
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
