Problem signature
SOURCE: Upgraded to win 7, now the black cherry, Signature
No driver is required to use the drive. Try another cable or another port on the computer. If you are using it bus-powered, try using a USB "Y" cable as some computers cannot provide enough power through one port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
SOURCE: I bought a LENOVO B
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
