Question about Compaq Presario M2000 Notebook
Replace Backlight compaq presario m2000 - Compaq Presario M2000 Notebook
Pyrhyc
  • 2028 Answers
SOURCE: VGA driver for Compaq Presario M2000
Here's a link to the driver site for your machine. Choose your operating system and it will give you the list of drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=433559&lc=en&dlc=en&cc=us&lang=en
Posted on Jul 25, 2008
ItWillBoK
  • 108 Answers
SOURCE: drivers for compaq presario m2000
Here you go:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=433559
Happy Holidays
Posted on Dec 24, 2008
  • 20 Answers
SOURCE: compaq presario m2000 audio driver
Get the driver from the compaq website.
Posted on Dec 23, 2009
SOURCE: how to replace backlight on compaq presario f700
There is much more to gaining access to the inside of the LCD screen than removing a few screws. You MUST remove the battery, remove the silver screws that are NOT indicated with the keyboard icon. Then remove the 2 screws on the bottom of the laptop near the corners that are closest to the hinges for the LCD. Then carefully remove the power button panel that stretches across the top of the keyboard. Under this panel, on the left side, you will see a connector with a black pull tab on it. This is the LCD data cable connection. Pull it straight out, lifting it up not side to side. On the power button board, you should see a screw, remove it then disconnect the LCD microphone cable located on the left side of the power button board. Locate the hinges on either side of the bottom half of the laptop, remove the 4 black screws. The LCD should be free to detach from the base of the system. The black and white wires going into the right side of the LCD assembly are for the wireless card antennas and need not be removed. Now you can remove the rubber feet going across the top of the LCD, the 2 rubber covers on the raised lower middle section, as well as the 2 plastic covers in the lower corner of the LCD assembly. These can be easily replaced. Use a small flathead screwdriver to remove them. Now remove the exposed screws. Separating the 2 halves of the LCD outer case requires a small flathead screwdriver. Start at one corner and pop it open. As you work around either side, you do NOT just pull it open. Doing this will break the locking tabs that hold it together. Use the flathead to gently push inward at the center of each tab, this will release them without damaging them. Once inside, remove the remaining hinge screws at the bottom sides of the LCD (silver screws). Then remove all remaining screws at the top of the LCD panel which fasten the panel to the back half of the LCD assembly. Lift the panel up from the top as if you were closing the computer lid. disconnect the LCD data cable then lay the panel back down again. Disconnect the pink and white wires from the LCD inverter at the center bottom of the panel, you may have to remove the inverter to do this. Also disconnect the inverter from the LCD cable. the LCD is now free to be removed from its housing. Gaining access to the CCFL (LCD backlight) requires you to remove any screws that may be holding the panel together as well as removing any tape around the edges. This is where the above post is WRONG. The bulb is NOT held in by tape alone. You will have to completely disassemble the LCD panel by seperating the glass panel from the rest of the layers. BE VERY CAREFUL NOT TO SEPARATE THE LAYERS. If you do, your screen will be depolarized and images will be distorted or discolored. You will have to then have it re-polarized. The bulb is encased in the plastic trim that holds the LCD layers together. It is located at the bottom of the screen. Once you gain access to the bulb, you may carefully remove it. If your planning on replacing the bulb, you can try to get the manufacturer to sell you a replacement but chances are they won't. Go to www.ccfldirect.com and order one. Keep your old one for a reference as you will need the measurements.
Posted on Apr 10, 2010
  • 77 Answers
SOURCE: download compaq presario m2000 audio driver
Hp Compaq m2000 Audio Drivers for Xp & vista Download Link::
CLICK HERE
Posted on Mar 21, 2011
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
Repair manual for compaq presario M2000
Free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Computers & Internet
Send me the laptop screen information
At first glance, we wouldn't elect the Compaq Presario M2000 the laptop we'd most enjoy cramming into a carry-on bag, but this economical desktop replacement is lighter than it looks, and it performs solidly.
The Compaq Presario M2000 is big and square--1.8 inches tall, 13.2 inches wide, and 11 inches deep--but it's very portable at 6.4 pounds. The power adapter adds less than a pound more.
Jun 01, 2010 | Compaq Presario M2000 Notebook
LCD Problem
Sounds like the backlight inverter of the LCD, It has to be replaced.
Feb 26, 2010 | Compaq Presario M2000 Notebook
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
No screen
The backlight in your LCD most likely needs to be replaced.if you are not familiar with it's removal and installation I suggest you take it in to a repair shop.
Hope this helps you..
Nov 21, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
14 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
