Question about Toshiba e-Studio163 Copier
Poor copy i cleaned drum mechanism but still the same problem
  • 30 Answers
Hi,clean optics,cleaning blade,corotron wires & expousre lamp.
Posted on May 21, 2009
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Our Sharp AR-160 copy machine is 5 yrs old. We have had to have continued maintenance, most recently the "developer" was replaced and our copies still come out faded. How long should we expect...
Did they clean the laser unit?
You can play with bias to raise the copy darkness.
For start you can open the front door and right side way door, remove drum unit, and you will be able to see long glass above drum unit. clean it with the dry wipe or wet one but be sure to dry it.
By my experience it is a good low maintenance copier... if the preventive maintenance is carried out correctly, every 60 000 copies more or less.
Hope that helps!
Dec 27, 2010 | Sharp AR-160 Copier
Poor image
Clean the beaneath the copy glass, clean the laser unit, polish the toner cylinder, and replace toner cylinder cleaning blade.
Jul 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
After a few copies are made, black streaks start showing up on the copies and gets worse with each successive copy
for most copier those black streaks are caused by poor cleaning of the Photo Conductor Drum these can be fix by replacing the cleaning blade. after replacing them clean the Photo Conductor Unit and make some test copies.
Feb 27, 2010 | Office Equipment & Supplies
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Sharp AL-1340 has black spot repeating 3 times on each copy.
The problem was indeed caused by a defect in the drum. The drum surface had a small spot where the coating was missing. The drum makes three revolutions during the copying of an 8 X 11 sheet and the defect is seen on the paper as three distinct black spots. The drum had been poorly packaged for shipment by the supplier. A piece of lightproof black plastic was wrapped around the drum to shield it from any light during transiting from the shipping box to the copier. This piece of black plastic was poorly positioned and wrinkled. Additionally, as received, the drum - sealed in a light-proof bag was jammed into the shipping box and I have no doubt that the defect in the drum surface was caused by this poorly packaged shipment. I reinstalled the old drum and hopefully I can finish the current job before the drum counter times-out and shuts down before I can obtain another new drum from that company.
Apr 09, 2009 | Sharp AL-1340 Laser Printer
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
MY COPIER COPIES ARE POOR
Have you cleaned the optic's? What is not clear with the copies? Are the blurred or black marks? When you clean the optic make sure you clean the scanning lamp also. Has the problem improved after replacing the drum unit? If not it may also be with the developping unit.
Nov 10, 2008 | Canon imageRUNNER 400S Copier
Cannon IR 400S Copier
1-en front door look inside and see if there are black rings around the shiny Drum cylinder, if yes replace drum blade (may have to replace drum also).
2- if lines only come when doing from ADF then lift top and clean the small strip of glass.
Sep 13, 2008 | Canon imageRUNNER 400S Copier
Toshiba e-Studio163 Copier Logo
41 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
