Question about Tally Line Matrix T6050 Printer
T6050 - Line printer shows message "platen open"
  • pravin71077 May 21, 2009
Bubbabear64
  • 2794 Answers
SOURCE: Tally T6050 line printer
Unplug the printer cable. Turn the power off. Wait 30 seconds.
Turn the power on.
If it is still printing, go into the conrol panel of the printer and clear the spooler.
That will clear the data out.
Posted on Jun 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: 057 close platen error message
Its located in the adjustment section of the platen control or in the platen itself.
Lexmark may still be supporting this model printer.
Posted on Dec 02, 2008
  • 378 Answers
SOURCE: printer shows message "platen open"
check the scanner cover
Posted on Jul 27, 2009
  • 5 Answers
SOURCE: I have a line matrix printer lipi 6306L. When I
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Posted on Feb 23, 2010
Saigua
  • 981 Answers
SOURCE: i am using LIPI T6050
Flip the DIP switch for test mode OFF.
Posted on Aug 06, 2011
Vibration in the paper ,as a result print is coming blurry in the T6050 printer.
release some gap by platen manually pull up. and calibrate hammer. for better printing
Jun 27, 2014 | Tally Line Matrix T6050 Printer
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
I have a lipi printer t6050. there is a problem showing shuttle fault. tell me what is this problem and how can i solve this
This error indicates the print mechanism is not able to move, in the first instance check;
There is no paper jams etc whcih may cause an obstruction
Check the ribbon is correctly installed and is the correct side of the ribbon shield
Check the platen gap to ensure this is not trapping the ribbon / paper and preventing the mechanism moving.
If the above actions do not resolve the problem the next thing to check is the Shuttle Mechanism,
Check the drive belt is in place and does not slip
Clean the rear side of the shuttle weight wheels, the sensor looks at the rear of the balanced wheels.
Check the shuttle motor to ensure it is working
Check for damage to the shuttle drive gears.
Dec 13, 2011 | Tally Line Matrix T6050 Printer
T6050 PSIS E 8200 LAN ERROR
I guess you are talking about a line of text printed on the T6050 when it is powered on.If this is the case you simply have a network card installed in the printer but have not connected a network cable.To resolve this problem either connect a network cable to the internal network interface or remove the internal network card from the printer if it is not being used.
Jul 22, 2011 | Tally Line Matrix T6050 Printer
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Printer driver for tally t6050 vista os
if you can't find that you try with install driver
epson fx1000
many line printer running in this driver
Feb 28, 2008 | Tally Line Matrix T6050 Printer
Tally Line Matrix T6050 Printer Logo
102 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
