Question about Frigidaire Refrigerators
Door won't stay closed
The refrigerator door won't stay closed
SOURCE: Refrigerator door stays open.
Sears came out and repaired my door with this same problem. It was a pretty easy fix. There is a small black part that the door rests on. It just was worn out. The repairman simply unscrewed the door from the top of the refrigerator. He lift the door off. The door normally rest on a black round circular plastic part about 1 in in diameter. It has a small plastic piece sticking up about 1/2 inch that the door rests on. This piece was worn on bottom. I have the Sears invoice and I bought a replacement bin for the door and I don't know which item is for the black plastic piece. Here are both part numbers so call Sears and order the correct part
CAM-DOOR 46 106 4318165 1 or $14.83
SUB TRIM-DOO 46 106 2156022K 1 $12.48
It took the Sear's guy about 10 minutes to repair. So save yourself $200 and do it yourself.
There is a picture of the part in the Whirlpool Manual, under Door Removal, look at the bottom hinge.
Email me if you need another picture.
lcbeaty2004@yahoo.com
Posted on Nov 27, 2008
SOURCE: Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Posted on Nov 30, 2006
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Posted on Jun 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: freezer door will not stay closed when closing
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Sep 04, 2009
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Nov 06, 2014 | Samsung RSG307AABP 30 cu. ft. Side by Side...
Gss25qgmd ww the flap on door dispenser not working. It won't stay closed what do I need to get to fix it.
you need a new door flap solenoid thats behind the dispenser display on the door
Jan 07, 2013 | Refrigerators
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
Fridge door won't stay closed
What is the model number of your unit?
Nov 03, 2012 | Refrigerators
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
Doors won't close independantly. Magnetic "strips " hit and freezer or frige stays open slightly
Has the unit recently been moved or the doors removed at any time? Either the door are not aligned or they are damaged around the hinges some how. I would adjust doors from the top of the unit, assure not product (food) could obstruct the door from closing. Lastly double check closer at the bottom, this is a two piece system and I had seen this come apart recently.
I hope this helps
Aug 11, 2011 | GE GSS25LGM Side by Side Refrigerator
HAVE A KENMORE REFRIGERATOR - MODEL # 253.60734407 - HAVING PROBLEM WITH THE MAIN DOOR STAYING CLOSED. IF I PLACE 2 LITES OF SODA ON THE DOOR. THE DOOR WON'T STAY SHUT. HAVE THERE BEEN ANY OTHER...
The main thing that makes a fridge door shut is that it falls shut because it is set at a slight angle with the front of the machine higher than the back. You may find the solution is as simple as making the fridge tip back a tiny bit more by turning the front feet clockwise to screw them out of the chassis and make them longer, causing the fridge to tip back a little and the door to fall shut as it should.
Jul 07, 2011 | Kenmore Refrigerators
Refrigerators Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
