Question about Mackie MR5-MK2 5" Powered 2 Way Reference Monitor
Loud buzzing when turn on, no input signal
Have been using these fine for a year, then all of the sudden the right monitor started emitting a very loud static/buzzing noise. At first I thought maybe I'd blown it but I don't see any signs the cone is damaged, and it now starts making the sound as soon as I plug it in, whether or not there is an input signal. I tried checked the fuse & it seems fine, I tried switching out the power cable and input cable one by one from the good speaker, but no change. Any suggestions? Thanks
    Novelist:
  • 170 Answers
Put a song onto play using either tape, vinyl, cd or mp3.
once playing follow the wires from the speaker that doesn't work bending it until you hear it crack or become clear if it does either of those it is the wire between the head unit and the output.
if not you can try attaching the speakers to a different head unit if it doenst work it could be the driver (the cone doesn't have to go to blow a speaker)
Posted on Jan 02, 2014
Testimonial: "Already tried switching the speaker to the good ((working) speakers power cable and input cable/wires with same result. Which leads me to a problem within the speaker itself.... checked fuse already as well. It makes sound with power only on. I was going to open the back and see if any visible issues with bad capacitors or ?? I have a little experience with solder/resolder work and probably can replace something if it's blown. I don't think my monitor is still under warranty, but I'll check. It's just over a year now naturally. Thanks"
Issues with turn signal in my 2001 Oldsmobile Alero. Hazard lights and right/left turn signal emit a very loud buzzing, then gets stuck. It does not work most of the time, or when it does, it buzzes...
Sounds like you have a bad multi-function switch or signal switch they are the same thing.This will fix the cruise control but,your other problem is your hazard warning switch replace it to.This will fix both of your problems.P.S you can get both of these from www.rockauto.com for less than $60.00.
Apr 20, 2011 | 2001 Oldsmobile Alero
We have a buzzing sound coming from the monitor speakers when we go to ANY internet site. It is just loud enough to be annoying!
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Jan 26, 2011 | Samsung SyncMaster 220WM Monitor
Speakers buzz with no sound
Is this only with CD, only with THAT CD, or with nothing in particular selected or playing?
Check all connections for tightness as bad cable shield connections will let emitted noise into the system. Ditto for signal or speaker cables routed near power cables, TV's, other electrical sources.
Sometimews reversing the AC power cord polarity can resolve buzz/hum.
Feb 20, 2010 | Philips HTS3440/37 System
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Audio fuzzy or cuts out
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Nov 26, 2007 | RCA HD61LPW165 61" Projection HDTV
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Mackie MR5-MK2 5" Powered 2 Way Reference Monitor Logo
82 people viewed this question
Top Mackie Computers & Internet Experts
Robbie Goodwin
_ST_
rostit
Are you a Mackie Computer and Internet Expert? Answer questions, earn points and help others
