Question about Compaq Computers & Internet
DVD ROM not responding. The icon is also not shown in 'My Computer'
    Scholar:
  • 70 Answers
Right Click "My Computer" and click properties.
from the properties menu on the Hardware tab click the device manager for windows XP else in Vista click you dont need to click the hardware tab just click the device manager on the top left
On the list of devices click the DVD/CD Rom Drives
on the open list you should see the name of your DVD ROM drive. If it has a caution sign on it then theres a problem with the driver. But if it does not have any sign on it then right click it and click uninstall.
Automatically your PC would scan fro hardware changes but if does not the click on Action and click scan for hardware changes. this would enable a fresh reinstallation of your DVD ROM.
If this does not solve the problem, turn off your computer and restart it and go to your bios using the F2 button or which ever button displayed at the bottom of the startup screen,
On the Bios, check your hardware devices to see if your DVD Drive is listed. if it is not listed then turn it off.
take out your DVD Drive from your computer by unscrewing the bolts holding it at the base close to the battery location. and slide it back in careful to make sure it sits perfectly in the connectors.
Turn it back on and try the Bios test again to see if its listed. if its not then probably your DVD drive is bad.
For further tests or repairs, see a technical repairer of your model of computer for a replacement or further physical tests
Posted on May 21, 2009
  • 65 Answers
If you cannot eject the tray that means the power to your DVD ROM is not connected, You need to open the computer panel to the side and inspect the connections, make sure they are tightly connected. Be sure to power off your PC and unplug it from min power source before you do this.
My pc does not recognizing optical drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Jan 19, 2013 | Dell Vostro 1510 Laptop
When i was burning a dvd it was ejected suddenly. After that it can't load any disc. Error shown was your cdrom is blocked... Is there any way to unblock my dvd rom.?
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 26, 2011 | Sony (CRX835E/11) CD-RW/DVD-ROM (Combo)...
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
I put the cd rom into the drive and nothing happens. I go to click on the icon under my computer and it causes the window not to respond.
Confirm that the CD drive is not a CD-ROM dive and the CD you are trying to open is is not a DVD. CD-ROM drive wil not open a DVD ROM and in some cases will cause the system to stop responding if youtry to run it.
Jan 26, 2010 | The Learning Company Oregon Trail 5th...
The disc medio tray will not open and will not run on hp g60
Hi I'm Rain ,
Ok follow these instructions to reboot your CD Rom drive.
  1. click start then My Computer .
  2. In My Computer right click the DVD/CD rom drive icon .
  3. In the list , Click eject to see if the drive is being reconized .
  4. If nothing happens repeat steps 1-2
Now when you get to sep 3 you will click properties .
5. In properties click Hardware .
6. In Hardware click the DVD/CD device to highlight it .
7. Click properties .
Now look to the bottom of that window to see device status .
If it says , this device is working properly .Properties .
Next click Driver . In driver you will see a list of option tabs that allows you to , Roll Back driver Update driver and Disable driver .
The other option is Driver Details.
Click Roll Back driver to restore the driver back to the state before you added the latest program . Click ok and follow the screen instructions.
If this fails , you can follow these steps to get back to Driver and chose
Disable Driver . Click ok if another window pops up.
Now what you are doing is rebooting the DVD/CD rom drive.
This will restart all the drivers that are associated with the DVD/CD rom
device .
Now follow all the steps again to get back to Driver .
Now in Driver you will need to click Enable to restart the DVD/CD rom
device . Reboot your system and try the DVD/ CD tray to see if it responds . If it still fails to respond you most likely will need to replace or service the DVD/CD Rom Hardware { the Tray } .
Jan 08, 2010 | HP G60-230US Notebook
DVD/CD-RW Drive
Try changing the power socket attached to your DVD drive with other available one, and restart your machine. If it is not yet shown in My Computer. try replacing the ribbon connector from motherboard to DVD Drive. If it is not yet shown in My Computer you try then to enter setup from start up to manually detect your DVD Drive. If you need to buy a new drive you can get it at any computer shop or at dell service center.
Apr 27, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
DVD-Rom's problem! Plz help!
* please check dvd rom cable(ide cable) is connected properly
* check powerconnecter is connected tight
jumper settings:
* set ur hdd as master
* dvd rom as slave in ide1
* set master to dvd writer in ide 2
Jun 19, 2008 | Computers & Internet
DVD burning
From your cryptic description, and the extremely limited details given.
Does the DVD even show up on "My Computer"?
If it is not shown...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click
the 'Device Manager' button. Click the "DVD/CD-ROM drives"). If there is some kind of a "Warning" icon superimposed on the 'DVD drive' icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 20, 2007 | Computers & Internet
Computers & Internet Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
