Question about Haier CPN14XC9 Air Conditioner
No cold air is coming out
Is not coming any cold air . so i like if is simple solution on that is was work good i turn it off and the next day is not work again . no cold
2004 yamaha kodiak 400, ran great, now it won't start the next day. kill switch was left on. slid it over, turned it on like i usually do to start it, nothing but a red light (temp ?). it was very cold...
hey Tammy... does the neutral light come on??? if not... find neutral..see what happens.. next.. have your batteries CCA checked.. (Cold Cranking Amps)...the amperage is what makes the starter work..NOT voltage...you can take it to Oreilly's, autozone, batteries and bulbs, or your local battery store...
Aug 16, 2017 | Yamaha 2004 Kodiak 400 Auto 4x4
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
2004 suburban one day ac worked fine the next day all I can get is heat and I can not shut it off
Startby having the freon gas checked,next would be a stuck blend door, this door is controled by an actuator motor, i would say the motor has gone bad if you cant get the hot air from coming inside, you turn to cold on the selector it shouldnt be hot air maybe warm depending on the temp outside,.
Aug 30, 2010 | 2004 Chevrolet Suburban
Freezer works fine but fridge portion is not getting cold enough
by any chance do you hear the fan on at all........reach into the top freezer and feel if any air is blowin out of the vents..........if no air blowin it might just be the fan motor......it might be defective........................more details would be good..................
Jun 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
Unit is icing up and not blowing cold air
Usually when this happens, the unit is low on freon. If you have an AC tech come out, make sure he does a leak check for you. Hope this helps... good luck!
Sep 02, 2009 | Samsung AW0505M Air Conditioner
MY 01 IMPALA AIR WORKS ON DAY NEXT DAY STOPS. HAD
You most likely have a bad vachum motor that operates the blend door if you need more help post a reply.
Jun 15, 2009 | 2003 Chevrolet Impala
Turning signals, flashers not working
You can use a pointed nosed pliers (or similar) to remove fuses..... The rain would not effect the turn signals unless you had a water leak into the flasher unit itself !
The A/C has to be fully charged to blow cold air and would not be on some days and then off the next. the refrigident gas would not change because of weather conditions. .........
A simple test lamp will indicate which fuse is functioning or otherwise without removal of same ! Good luck
May 17, 2009 | 1998 Toyota Sienna
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Haier CPN14XC9 Air Conditioner Logo
32 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
