Question about Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &...
Removing door handle westinghouse side by side fridge
Need to change one of the brackets that are broken
2 Suggested Answers
  • 400 Answers
SOURCE: I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
Posted on May 27, 2009
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
My freezer door handle has come away at the top how can i fix it mysel
If handle is broken get a new one and by removing inner door panel install the new one. Parts available at attached link Search Over 2 1 Million Appliance Parts
Mar 02, 2016 | Samsung RSA1SHPN American Platinum Inox...
I want to remove door handle on model RS663V*7 side by side westinghouse refrigerator?
Thanks Tyler T and L fortunato. I just gently but firmly gripped the handle with both hands and pulled it up and it popped out. Wear some rubber gloves to gain more grip. No card required. Now I know what parts to buy. They are all small plastic pieces attached to both the handle and the fridge door itself.
Oct 31, 2012 | Westinghouse Refrigerators
How do I replace the door handle on fridge side of westinghouse 610l side-by-side fridge/freezer? what tools do I need?
No video for westinghouse, but hope, this will help you.
http://www.youtube.com/watch?v=QcSr0S_SiGs
Thanks.
Feb 07, 2011 | Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Change doors of fridge freezer from right opening to left opening needless to say cannot find instructions after 10 years
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
Mar 13, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
How to change the doors on fridge freezer
Good day,
First. Save and mark all shims and bushings you remove in the process. As well remove all food from both doors.
1. Remove bracket from top of the refrigerator with the door closed.
Once removed, open top door with 2 hands about 1 foot.
Lift off.
2. Remove center bracket and remove as in step one.
3. The bottom bracket can be removed and mounted on the other side, reversing it's orientation. (pin sticking up).
4. remove both handles and remount on other side.
There are many plugs that must be removed, to uncover new screw holes. Some may be covered with emblems, but can be pried out with a small screw driver.
5. Reinstall in reverse order checking for alignment as you proceed.
6. Push in all removable plugs when complete.
Nov 30, 2009 | Refrigerators
May 27, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridge doorhandle bracket
Possible the source of the trouble you are having is the bracket might not be available or available separately.
Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts.
I suggest you ask the service department to fax or email a drawing to you.
Mar 28, 2017 | Amana AFD2535DES French Door Refrigerator
Refrigerator Door Reversal
you can switch most makes without extra hardware
Aug 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &... Logo
27 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
