Ipconfig not working - Computers & Internet
I have a compaq presario SR1303 Wm Desktop I wont connect to internet, stating that local area cable is unplugged, however this isn't true because I have another desktop same model that works fine...
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Aug 31, 2012 | HP Compaq Presario SR1303WM (PP150AAR) PC...
Computer working offline wont let me connect to internet
the easiest thing to try would be to restore from the last good point. have you done that?
let know also if you recently installed anything.
if not, we can try to renew the TCP/IP
ipconfig /release
ipconfig /renew
ipconfig /flushdns
ping neosmart.net
ping 209.200.246.147
Mar 25, 2011 | Sony Computers & Internet
The Internet Exploer is not working, the Wi-Fi Power is on and I'm connected but I can't get on the internet.
Hi chapy76. Try this steps in solving your problem: For Windows XP:go to start>run>cmd>in the black window, type "ipconfig /release">then type in "ipconfig /renew". it should solve your problem.
For Windows Vista/Seven:go to start>search cmd>in the black window, type "ipconfig /release">then type in "ipconfig /renew". it should solve your problem.
Feb 19, 2011 | Sylvania G-Netbook
Can't connect to the internet. get this error when IE diagnosis connection problem: "the DNS server isn't responding". My internet was working fine earlier today, and just quit working. Did an...
Try 'IPCONFIG /RELEASE', then 'IPCONFIG /RENEW', to see if your computer can obtain a new "lease" from your ISP's DHCP-server. If not, telephone your ISP, and get them to trouble-shoot from their end (peeking into your cable-modem).
Try power-cycling the cable-modem, and any wired/wireless router that is in the mix.
Dec 18, 2010 | Computers & Internet
How do I reset network connection on laptop so it reads my router.
try Start Run CMD
ipconfig /flushdns ipconfig /release ipconfig /renew
if this dosent work go to Device manager and delete the network card and reboot this will cause it to reinstall the NIC card and it should pick up the router upon internet discovery phase
Oct 12, 2010 | Computers & Internet
I cant get internet
goto the command prompt and type ipconfig if you don't see 192.168.x.x then you are not connected
then type
ipconfig/release
then type
ipconfig/renew
This will work of you have a working ADSL line and router.
Sep 17, 2010 | Computers & Internet
I can't get my ip address back. i tried run, ipconfig /renew and it did not work.
Hello did you release your ip address first?
Start> Run> ipconfig/release> ipconfig/renew
Jan 27, 2010 | HP Pavilion dv8230us Notebook
I cant connect to the internet now using my laptop, Says it connected to my home hub, but wont connect to internet
sometimes restarting the rourter helps. unplug it, wait a minute, then replug it back in. and restart the laptop. if that doesn't work, try this..
click start....click run...type cmd then click ok...copy and paste this into cmd window...
ipconfig /release
ipconfig /renew
ipconfig /flushdns
ipconfig /registerdns
exit
that should help and if THAT doesnt work, go here..and try the solution as it might need a winsock-lsp repair... http://cexx.org/lspfix.htm i hope this helps merry christmas.
Dec 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Ipconfig is not working on my laptop
Check what is the ipaddress,tried to shut down the laptop and drain flea power.Then check if the laptop can detect wireless connection. Then ping website in command prompt.Try ipconfig /release and then ipconfig /renew. Try connecting wired internet connection to check if issue with operating system or browser or wireless connectivity.
Aug 17, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
