Question about Haier CPN14XC9 Commercial Cool Portable Air Conditioner, 14,000 BTU, 3 Fan Speeds, LED Display, Remote, Removable Air Filter, Direct Drain Option
My Commercial cool . portable 14,000 aircondition is stop air cool coming out .
Now avery time put the air por cold air is is not work it . just fan is blow it . it was working very nice now is not . any can tell me the solution . ?? air.commercial cool . portable air/c 14,000
  • 29 Answers
SOURCE: I purchased a Commercial Cool Haier portable
Check the compressor. It probably fell out of it's mounting bracket during shipping. Maybe turned upside down or something. Make sure the compressor is sitting solid and it's rubber feet are in place. If you continue to use this unit with a loose compressor, you may damage or break a refrigerant line.
Posted on Jul 08, 2010
SOURCE: HAIER CPN11XCJ new, doesn't blow cold
There are three settings. If you have it on FAN, it won't blow cold. The raindrop picture is for dehumidifying, and the snowflake picture is the setting for COLD. If you shut the unit off and on too quickly, it takes a minute or two to cycle back to cool.
* Make sure the 'snowflake' setting/picture is selected...
Ours works too good! We sleep with 2 blankets! Nice...
Posted on Aug 21, 2010
heatman101
  • 43501 Answers
SOURCE: the unit suddenly stopped blowing cold air. the
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Jun 12, 2011
  • 4736 Answers
SOURCE: My commercial cool air conditioner
It's going thru the defrost cycle. Once that ends, the unit should restart. If it doesn't wait until 3 minutes have elapsed, after the stop light goes out and restart the unit. If that fails, turn the Master ON/OFF Switch to OFF & unplug the unit. Wait 15 minutes, plug the unit back in and turn the Master ON/OFF Switch to ON. The unit should have reverted back to the original factory settings. If so, reset the controls as you like.
I hope this helped you and thanks for choosing FixYa.
Posted on Jul 24, 2011
  • 4736 Answers
SOURCE: I have a commercial cool
Karen, the flashing red light indicates that the water collection tank is full and needs to be emptied.
You can finds the drain plug on the rear of the unit just above floor level.
It can either be drained into a low sided bowl or pan capable of holding 1 quart of water. or you can disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Posted on Sep 06, 2011
Why is the air not cold enough when the ac is on
You have probably leaked refrigerant and need some more to replenish what you have lost. You might consider refilling with the refrigerant that has some stop leak in it to seal up any small leaks so that you do not lose the freon again.
With two wrenches tighten up all fittings in the ac line. Over a period of time, the engine vibrations and aging will loosen them and cause systems to leak.
Jun 20, 2016 | American Exchange Comfort 14,000 Btu...
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
Unit is off and displays blinking stop and won't come on...
My unit shut down in the middle of the night and had the blinking STOP on a dark screen, would beep 10 times when plugged in aswell. I set the unit on top of a pan and opened the bottom water drain plug. After draining alot of water out the unit allowed itself to be turned back on again. Guess its either extremely humid or the dual hose setup doesn't evaporate the water as fast as they made out. Anyways, I haven't found anyone else post this so I hope this helps someone out there.
Sep 26, 2012 | Haier 14,000-BTU Commercial Cool Portable...
My braker keeps tripping with only the tv on and electronics that barely use a lot of juice. it doesn't seem like it pumping out enough cool air for 14,000 btu's either
14,000 btu is a very large unit it should be on a dedicated cuircut of either 15 or 20 amps all by itself.check the rating plate for correct amperage
Jul 21, 2011 | Soleus LX-140 Portable Air Conditioner
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
Haier CPN14XC9 Commercial Cool Portable Air Conditioner, 14,000 BTU, 3 Fan Speeds, LED Display, Remote, Removable Air Filter, Direct Drain Option Logo
26 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
