Question about Water Heaters
My honeywell water heater SV9570A 2062 lites up for about 5 sec and then goes out
When it first started you could turn it off and on a couple of times and it would stay on and work. After a month it gradualy got harder and harder to get to stay on till now it want stay on but 5 sec and thats it.
  • 161 Answers
The flame rod could use cleaning with some steel wool. The other thing is the pressure switch on the inducer might not register the air flow.
Posted on Jan 02, 2014
4 Suggested Answers
robocop
  • 90 Answers
SOURCE: Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Posted on Jan 22, 2009
SOURCE: gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
Posted on Apr 10, 2009
gary1121
  • 332 Answers
SOURCE: Bradford White LP water Heater Power vent
does the fan come on, if not there is a problem with the circuit board, if it does then there is a problem with the gas valve or a wire from the gas valve to the fan , if the fan doesn't come on the gas valve is told not to open to light thru the circuit board,
Posted on May 30, 2009
How do I change the thermo couple on a Honeywell water heater
turn off gas and power then small silver line connected to gas valve goes down under burner and has two wires going to gas valve take picture before taking apart then replace and relite pilot
May 10, 2016 | Honeywell Water Heaters
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
Hi im having trouble lighting my water heater and turn the water to hot. it says push and hold the knob and repeatedly press until pilot ignites.
after pilot lite you got to hold it down for 45 sec before you can turn it on..if you still having trouble get a qualify technician to relite it.
Aug 09, 2010 | Honeywell Water Heaters
I have a 6 gal water heater i lite the pilot and turn to on and it runs for awhile then just shuts off
It could be a couple of things, the thermocouple may have gone bad or the actual control has died. I assume that the gas valves are open and in case of propane you have fuel in the tank. water heaters last 5-10 years so replacing the control on a older unit is not cost effective however thermocouples don't cost much.
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot Light problem
By controler I am guessing you mean gas valve? The next step, and I am not sure the water heater age rates this ,is to replace the gas valve.
Mar 13, 2009 | Water Heaters
Water Heaters Logo
112 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
