Question about Brio Toys
Brio battery operated engine does not work
Battery operated engine
How can i send my engines for repair
Here's the link to BRIO Customer Service, contact them for instructions.
Customer service BRIO
Jul 06, 2014 | Brio Mighty Red Locomotive
Where is the battery located in the engine?
They are two AAA micro batteries.
Insert a cross-tipped screwdriver into the funnel of the engine, unscrew completely and the black nose comes off, revealing the batteries.
Jul 29, 2011 | Brio Mighty Red Locomotive
How to change the battery in train 512
Hi Tarja, your question is 4 years old, but here is the answer:
You've probably seen the odd shaped tiny screws on the underside of the train. Ignore them - they require specialized tools and only lead to the wheels and gears.
You just need to insert a small cross-tip screwdriver into the exhaust funnel of the engine and remove the screw completely. The black front of the engine comes off and reveals AAA micro batteries which you gently shake out of the engine and replace.
As ever so often - once you know how to do it, it is very easy.
And - no, I didn't find out myself either *grin*
Nov 08, 2009 | Brio Mighty Red Locomotive
I don't have a Brio triangular screwdriver
The battery is easy to replace. The screw is located in the black "smokestack" and will require a small size phillips-head screwdriver to unscrew. The rest is easy--lift up on the black smokestack (I usually leave the screw in place), and the two AA batteries are located end-to-end in the body.
Oct 24, 2009 | Brio Mighty Red Locomotive
Polar express battery powered wood engine works and then doesn't
Try forcing a tiny hex screwdriver in the triangular hole.
Almost certainly a lose wire that you can solder back.
A great sense of achievement will result given that you didn't have to buy another one from China and trash yours!
So annoying that Brio have to use these screws given how flaky their toys are - they are almost designed to fail as the wires are so short they break quite quickly.
Sep 05, 2009 | Brio Polar Express Battery Engine
My granddaughter has about a dozen Brio batter-powered locomotives. Three of them will not move, even with new batteries. Two of them still light their lights and make train-whistle sounds. But they won't...
Alas, the traction drive on these Brio locomotives seems to have a pretty short life. According to a Brio rep, the only hope is to indeed give it a good firm solid whack down onto a hard surface (table or floor) in an attempt to get the internal pressure gears to settle down and get more traction. There's a 50/50 chance it might work. There is no other solution. Attempting to open it up will create a mess because it's almost impossible to get all the tiny loaded springs back into place. At least the lights and sounds still work, and it can be easily pushed around the track--it just will no longer do so itself...
Mar 06, 2009 | Brio Mighty Red Locomotive
Need to replace battery in brio big red engine
There is a battery down deep in the steam spout on top (black chimney type thing). Unscrew it and it slides off the front and allows you to insert 2 AAA batteries.
Dec 08, 2008 | Brio Polar Express Battery Engine
Contents of the Brio
Brio D-150 Zoom or C-1 Zoom camera, 8MB SmartMedia Card, (1) CR-V3 Lithium Battery Pack, Camedia Master Software, Win/MAC USB Cable, NTSC A/V Cable, Instruction Manual, and Carrying Strap.
Aug 31, 2005 | Olympus Camedia Brio D-150 Zoom Digital...
Toys Logo
Top Brio Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Brio Toy Expert? Answer questions, earn points and help others
