Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
I have a jacuzzi 7c-s/b jet pump running water from the lake to the house. tonight the pump won't stop running and the pressure doesn't go any higher than 10 and the water is coming out a rust color. what is my problem and how do i fix it
SOURCE: Watering system pump cycling off and on rapidly. .
Still need help. No responses!
Posted on Jun 30, 2009
  • 10 Answers
SOURCE: jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Posted on Oct 24, 2009
  • 8404 Answers
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
Posted on May 15, 2010
  • 126 Answers
SOURCE: pump cycles like crazy!!
Sometimes a new tank the blatter will be kinda sealed to the sides of the tank.the amount of air in the tank s/b equal to the cut in pressure of the pressure switch.(40 lb) that would be (60 lb) cut out if you messed with the little screw on the pressure switch you have a problem.there must be the 20 psi of differance between start and stop.
Posted on May 17, 2010
2coolrick
  • 560 Answers
SOURCE: I have a FP 4022-10...it is relatively new but
If you can meet your needs with the pressure you have now, reduce the pressure cut off switch pressure until it shuts off. Your housing is probabbly sealed to the motor. Try shocking it with a rubber mallet to break the seal.
Posted on Jun 03, 2010
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
My jacuzzie starts and stops wen it is runing i have a fl code
FL is a flow error, you may not have enough water going over filter housing. Jets are they open?
is your heater fitted with a pressure switch? when on FL locate pressure switch wheel and turn all the way anti clockwise until it stops then slowly wind back until you hear a click reset in control box - you have reset pressure switch.
If you have done this and still show FL or heater is not fitted with pressure switch then your LOW speed on pump maybe faulty (new pump) or heater maybe scaled up with lime scale and reducing water flow through heater - remove scale from heater, flush through and increase ANTI-SCALE
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 07, 2010 | Jacuzzi Pool & Spa
I have a FP 4022-10...it is relatively new but will not generate enough pressure to actuate power cutoff, so the pump runs till I unplug it. I have verified that the line to the lake is clear (water...
Jun 03, 2010 | Flotec Corrosion Resistant Shallow Well...
Problem with Convertible Jet Pump 3/4HP RedLion - drawing water 300' from lake to cabin - when the pump is on it holds 50# pressure by itself but when tap is turned on the pressure drops to 30# then you...
If I understand you correctly this is what you have:
- A pump that draws water from a lake 300 feet from lake to your cabin (I assume the pump is at the cabin)
- The pump kicks on to maintain pressure in a tank that distributes water to faucets in the cabin. The pump only turns on to pressurize the tank when water is being used (I am assuming).
- When you turn on tap, pressure in the pressure tank drops to 30 psi, then you hear water sucking from the tank to tap and flow stops at tap. Then the pump finally kicks back on and pressures tank to 23 psi.
- The pump is not used regularly.
If water flow stops when the pressure tank is reading 25 psi, then likely the real pressure is 0 psi and pressure gauge is reading wrong. If this gauge is tied into a switch that starts and stops the pump, then this is probably your problem. You may have partial blockage in your pressure gauge/switch that is causing gauge to move too slowly to keep up with the actual pressure changes when water is being used. Ore the pressure gauge/switch may be broken. Pressure gauges are notorious for reading pressure when there is none. If you can unplug the pump and disconnect the pressure gauge/switch and check for blockage in the ports you should start there. You mentioned that this worked good for the last two summers, if if sits unused for long periods, it could promote bio-growth, rust and/or sediment in the connection to the pressure gauge. If you find blockage, remove it and flush it out. Reinstall the pressure gauge/switch and try it again.
One other possibility is clogged strainer(s) / filter(s) in the water lines. It would not hurt to pull and check/clean any strainers / filters in the system including before the pump. I would even check at the lake for a strainer where the water enters the suction line to the cabin.
I would not assume that the pump is the problem yet.
Hope this helps.
May 01, 2010 | Plumbing
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Jun 08, 2009 | Plumbing
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 | Home
Some of jet points inside jacuzzi are not mixing air with water
the jet are pushed by the impeller (it's like a fan blade) run by a moter water is pushed through the plumbing and out the jet head . when you open an air valve air is mixed in .
Feb 03, 2009 | Pool & Spa
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
49 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
