Shuts down restarts
Computer shuts down wi th out warning and restart after 5 or6 minutes other wise I have to unplug and plug back
devildox
  • 40 Answers
SOURCE: My Acer Aspire AST180 shuts down with no warning
Sounds like you have a faulty power supply. The internal parts of your pc produce alot of heat, and if a part is heating up, then it will cause your pc to shut off.
With you saying that unplugging it , and then waiting , and then it comes back on, it sounds like once some part has cooled off, then the pc works.
My bet would be your power supply. Do make sure however, that all your parts are still tight in their sockets.. ie processor, memory , etc. I saw a pc that shut off at random times because the heat sink didn't make good contact with the processor once in college. So you want to check those things.
Posted on Jun 23, 2008
SOURCE: Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Posted on Jan 10, 2009
billspeer
  • 180 Answers
SOURCE: Dell Dimension C521 power shuts off spontaneously
It sounds like your power supply fan may be overheating. The easiest way to determine this is to open the case and look at the fan while it is spinning- if it is indeed spinning at all. I find the best way to get an idea of the functionality of the fan is to shine a flashlight on it at an angle. If you can detect fluctuations in the rpm visually, you know where the problem is. Then it's a matter of changing out the power supply. If, however, the fan seems to keep the same rotation speed constantly, we'll need to look further. Let me know what you find out before we go deeper into the system.
Posted on Feb 23, 2009
gurutim
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
SOURCE: My gateway dx4300-03 starts up
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Posted on Nov 23, 2010
Testimonial: "Thanks I will try it"
I shut down my computer now I can not get it to turn on when I push the power button
Unplug the computer and hold down the power button for 15 seconds, and then plug it back in and see if it will re-start.
Jun 12, 2011 | Dell Inspiron 530 Desktop Computer
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52computers
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
While trying to set up with my WyFlyer WDB20B it lost or changed the IP address and Ican not get it to communicate with my computer. How do I reset the IP address or determine what the new one is?
shut down your computer, unplug the hub for about 1 minute. plug it back in then turn on your computer. if it still can't find it, do the same thing, but after unplugging your hub, there is a reset switch in the back, very tiny hole. press for 5 second to restore factory settings and then plug it back in and restart your computer.
Feb 03, 2010 | Computers & Internet
How do i reboot my pc
Read the Below Guide How to Reboot :-
http://www.ehow.com/how_4479754_reboot-pc.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 09, 2009 | Computers & Internet
Just bought a new Windows Vista HP and when I type a letter on yahoo the ''letters are missing in every other words?''
try shutting it down and restarting the computer shut it down for about 5-10 minutes then restart it when u shut it off unplug the keyboard and just before you restart the computer plug in the keyboard
Sep 05, 2009 | HP Computers & Internet
My hp dv9000 does not load windows properly the screen goes blk
I had this problem on my Pavilion DV6000. When I spoke to tech support they told me to unplug my computer and take the battery out for 5 minutes then replace it. I do not know why it worked but it did.
http://www.rexxindustrialparts.com
Aug 17, 2009 | HP Pavilion dv9000z Notebook
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
