Question about Konica Minolta bizhub C450P Laser Printer
Konica Minolta c450 Network Print- Data comes at the machine end but no print
WhenPrint fire from the PC data is comes at the machine end showing DATA led blinks in the machine console , but no print, but SCAN works fine, Ping properly without any loss of data. Please help
  • Konica Minolta Master
  • 6,696 Answers
Does this happen with word , pdf, web pages, email? what other indication display on screen
Posted on Jul 04, 2016
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 15 Answers
SOURCE: Konica Minolta C450 status is offline.
Change the status to "Online". Sounds crazy, but most likely you print driver is set to enable "SNMP" on the port settings. Disbale this setting in the print driver, also set print Queue to "LPR" and name the LPR queue as "printer". Make sure there are no jobs int he queue when you change the port settings.
Posted on Jun 09, 2009
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta c450 machine status s1
The CCD (Charge Couple Device) That large black looking thing under the big glass with a lens looking thing on it. That's what covers the original document in data for the laser to put on the drum. Well it is failing its internal calibration. Trying cleaning the lens DO NOT REMOVE THE CCD ASSY IT IS SET A SPECIFIC DISTANCE and angles it will mess up you copies only tech should do it. Use DRY rag. to clean the front end mite clean both sides of the large glass and refelector of exposure lamp.
Mar 24, 2014 | Konica Minolta bizhub Office Equipment &...
I have a konica minolta c450 and it displayed error c-d 370. I cleared it using 0-7-1-3-9 as instructed but on switching on the machine,on the screen it asked me to enter serial number and call ser
Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Feb 06, 2014 | Konica Minolta bizhub Office Equipment &...
per last, Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Konica minolta bizhub c450 error codec-d357
DID you swap a board from a different machine if so you really messed up the machine, Have a tech come out to look it over mite run below? NVRAM holds the serial number and counts so people cant erase the counts as new.
CD3##: NVRAM Data error
• When the data stored due to the NVRAM trouble is lost, backup data can be used for restoration.
• Trouble code [C-D370] will be displayed when multiple errors (over 5) of NVRAM data are detected, which can be restored with one restoration command.
• Data backup will be automatically performed every hour. Backup can also be performed manually with the following setting.
[Service Mode] ? [Enhanced Security] ? [NVRAM Data Back Up]
Touch the following code on the trouble code display screen.
Stop ? 0 ? 7 ? 1 ? 3 ? 9
2. [*] will be displayed on the trouble code screen.
3. Touch [*].
4. The screen will be shifted to the data restoration screen to perform data restoration.
NOTE
• When the restoration is performed in a short time, data restoration screen may not
be displayed.
5. Check the message which indicates that the data restoration was successfully conducted.
Turn Main power OFF, and wait for ten seconds or more to turn it back ON.
Sep 17, 2013 | Konica Minolta bizhub C450P Laser Printer
C450 c-d370
NVRAM Fault have a Konica Minolta Technician come out and flash the NVRAM and update the software, you can not do it yourself the website is a secure web site for the software. NVRAM could have failed also meaning it needs to be replaced. NVRAM keeps very important data for the machine. it is battery protected incase lost of power. A small board connected to the main board with chip and battery.
Oct 29, 2012 | Minolta Office Equipment & Supplies
I have a problem with my Konica minolta,it is a system Error C0500,what is this error for and how to clear it
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 08, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C450P Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
