Question about ASUS Computers & Internet
After logging on to my netbook only the on screen keyboard is shown on a black background
Netbook boots then comes to the welcome screen After logging on All I see is an on-screen keyboard
  • 44 Answers
Hello, the screen keyboard used for entering your password, if you have a password, enter it, if not click the escape key.
Posted on Jun 13, 2014
  • Roderick Maloney
    Roderick Maloney Jun 13, 2014
    enter your password or click the escape key
flipbooks
  • 177 Answers
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Posted on Jul 31, 2009
SOURCE: My asus 1000hp netbook has a locked keyboard, and
Keys 7, 8, 9, 0, U, I, O, P, J, K, L, and M are permanently stuck as if Fn is pressed so it is in the number-pad mode. So I can't type the above keys at all. If I want to type 0 I would have to type M. Obviously I am using a different computer now, just in case anyone is wondering. So does anyone have any solution to this? Please help!
Posted on Feb 10, 2010
  • 7 Answers
SOURCE: Acer Aspire One Netbook 8.9' Won't Boot Up !!!
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This is also known as crisis disk mode.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, with the flash drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS. After a while the button stops blinking, and the AA1 reboots shortly after. Wait patiently.
If it doesn't reboot by itself, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Posted on Jul 18, 2010
  • 3940 Answers
SOURCE: Hi. I have a Dell Inspiron 910 netbook. I'm
In newer model systems with XP SP3 or Higher, most likely a hdd failure.
Hold the Fn button while powering on system to run diags, see if the HDD fails the PSA Diagnostics.
Posted on Aug 03, 2010
kaywon17930
  • 203 Answers
SOURCE: Samsung N130 netbook I can
Hello, Look for the screen splitter key Try to press the Fn key + screen splitter key
Posted on Jun 03, 2011
When turning on the netbook, it load then the screen turns black for about 5-10 minutes before reaching the login screen. After logging in, the screen is just grey and stays like that. What's the
Try a system restore/recovery to a date before this issue. Have you done any hardware or software changes or updates? Graphics updates. Shut down, unplug, remove battery, plug in boot and follow this procedure: Please restart your computer, and hold down the F8 key before the Windows logo appears. On theAdvanced Boot Options select Repair your computer, and then press Enter. Select a user name, type the password, and then click OK. On the System Recovery Options menu, click System Image Recovery, and then follow the instructions. Take a look at this procedure from Asus suppot: http://support.asus.com/Search/KSearch.aspx?SLanguage=en&keyword=restore&ps=10&pn=1&st=knowledge
Dec 16, 2012 | ASUS Eee PC 1005HAPU17BU Netbook
Screen goes blank when any key is pressed
Open your netbook and remove the ribbon connecting the keyboard to the motherboard and the screen cable (long and black cable) and dry it out (DO NOT GET WATER ON THE MOTHERBOARD it will break COMPLETELY) YOU ARE very very lucky id didn't already and replace and tell me if that worked
Sep 15, 2012 | Acer Aspire One AOA150-1784 Netbook
Screen stays black after boot up
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Jan 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Worth trying to fix keyboard on Samsung NF310 netbook after a 6 foot fall?
Hello, considering the incident, you were lucky. I think the keyboard is worth the repair cost as you are able to use an external board and it works. The replacement is fairly simple and other than the cosmetic crack, your system should work just fine. Good Luck .
Dec 23, 2011 | Samsung NF310-A01 10.1-Inch Netbook (Titan...
My notebook is having trouble to start up. Something to do with bootdriver having issues,how can I solve ?
HI. Welcome to Fixya. Restore from the Recovery Partition
  • Start your netbook and tap the F9 key on your keyboard until you see a loading screen.
  • The restore program prepares the files needed for the operation.
  • A message appears asking if you want to perform the operation, you will lose all files on your computer.
  • Confirm by clicking .
  • This will restore your netbook to factory settings and without any action on your part. Finally we should rather say the Ghost.
  • At the end of the operation, the netbook will reboot on its own, and finish these configurations.
  • A reboot is performed again, and you're on the setup process of Windows as the first boot after buying the netbook.
Hope this resolved your issue.
Thanks for contacting Fixya. Bye for now.
Jul 16, 2011 | ASUS Eee PC 1001P Netbook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
2/3 of display is black
Strange could be video card issue or broken screen. try connecting it to TV or another monitor see if the picture is clear than video card is fine and display is damaged
Mar 02, 2011 | HP Mini 1000 Netbook
My advent netbook 4213 won't display anything on screen. Not even the boot up process It's just blank but if i look really closely i get verticle and horizontal very faint black lines how can i fix this?
check the wireing between the screen and under the keyboard.you mak have a loose cable, or you may have to replace the sereen, Did you try hooking you laptop up to a monitor via the external outputs?
Jun 27, 2010 | Advent Netbook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
