Question about Fisher and Paykel Refrigerators
N375t fisher paykel
Door adjustment
4 Suggested Answers
SOURCE: rehang fridge door on left
Hi
We decided to call a refrigeration engineer as we do not seem to have the required parts.
Thanks
Gail
Posted on May 17, 2009
localwonder
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
  • 54 Answers
SOURCE: i cleaned out ice bin and now ice will not make on fisher paykel
did you turn the oce maker back on also check that when you pulled the bin out you did not pull the powr plug out of the side of the freezer just enough it don't work
Posted on Apr 22, 2010
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
How do I adjust the sealing of the door when closing
The adjustment for this is usually on the back or side of the motor unit. Clockwise movement of the screw will lower the door position - keep adjusting till it seals. Do not over seal because then the door will reverse itself as the obstacle circuit might kick in and open the door.
Dec 25, 2014 | Building Materials
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Oven door on F@P oven not sealing
Check seal on door, and then see if your hinges are adjustable,
May 30, 2014 | Fisher Paykel Fisher & Paykel OB24SDPX1...
How to set up ovendoor
Check to see if you can adjust the hinges, it sounds like you also may not have the door completely set on the hinges
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Oct 25, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
The door on my front loader won't open it has done a 30min cycle
my fisher and paykel door is jammed and is stuck on 1 minute timing won't start
Jan 14, 2011 | Fisher and Paykel Fisher & Paykel Washer
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
Refrigerators Logo
16 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
