Question about Refrigerators
Bosch intelligent frost free 44
The fan in struggling to start
5 Suggested Answers
  • 87 Answers
SOURCE: How do I change the
reach behind the flap and pull on it .
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
imufo2
  • 3773 Answers
SOURCE: Bosch Intelligent Frost Free 44.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 08, 2011
I live in York WA and require a Bosch Intelligent Frost Free 40 fridge/freezer.. fridge door seal. Would like to know how much... and where to purchase? Gail
you can go online and search for the part using make and model their are 100s of appliance parts suppliers or go to bosch site and either order or request a supplier by you
Apr 23, 2017 | Bosch Refrigerators
On the bosch Intelligent frost free 44, if I want to check on the gas, who many gm gas do I put in. If the compressor doesn't put off, what can be wrong.
Gas in fridges and feezers are expensive to refill, if the unit is more than a few years old may be better to replace, if less than 12 months old should contact seller under warrenty.
Feb 27, 2017 | Bosch Refrigerators
I have a Bosch Intelligent frost Free 44. It keeps on switching on and off the whole time but when I leave open one of the doors, it runs normally. What could the problem be?
faulty thermostat
the thermostat presets on on/off temperature is faulty and when the door is close it is cycling but when the door is open the cycle is not allowed to happen because the on tremp is engaged full time
get a technician in to properly diagnose the fault and quote .
Aug 30, 2016 | Bosch Refrigerators
Intelligent 44 frost free. Why is the compressor not starting up?
The thermostat controls when the compressor switches on ,it does not nun all the time only when the temp rises, if the thermostat is ok and the refrigerator is hot it could be a faulty motor or compressor .
Jul 09, 2015 | Bosch Refrigerators
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
Bosch Intelligent Frost Free 44. Freezer on top. Water leaking at bottom of front door. What is the cause of this problem and how can it be fixed.
Leo Ponder
imufo2
Aug 07, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Feb 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
