Question about Caterpillar D399 Generator Drive Engine
I have cat D399 wont start? when i crank it with air starter its run as long i hold the starter on whehn release the starter botton stopped?
  • 3,187 Answers
If i remember right there is a solenoid valve on them when starting it has to be down for engine to start. if it fails it dont get the pressure needed to start. when engine is running and warmed up it opens. cannot remember were it is but I used to have one a long long time ago. and it was this fault.
Posted on Jan 10, 2014
I have a 94 jeep cherokee that wont turn over or wont start?
No cranks is here
https://www.jeepdied.com/no-crank.html
TURNS OVER MEANS ZERO.
the starter just CRANK.
THE START MOTOR TURNS
IF lucky so does the crank shaft turn.
then the engine starts and runs, (this is not turns)
it's running
the EFI then sustains running , if ABS stays happy.
the engine can also stall.
Mar 13, 2015 | 1994 Jeep Cherokee
I have a 2005 mitsubishi outlander. It wont start after I ran out of gas. I bought a new battery but the car still wont start
It's still out of gas until the lines are purged of air. The fuel pump has to run awhile to build up pressure. Keep cranking. If you can take the small gauge wire off the starter easily,all you have to do is turn the key to the start position and hold it there for a while. Listen for the fuel pump. When it slows down or stops then reconnect the wire and it should start.
Sep 11, 2014 | 2005 Mitsubishi Outlander
Mass air flow sensor location and diagnos
Look at the oxygen sensor. If the map was bad you'd get a overheated catalytic converter.
Jan 09, 2014 | Pontiac Grand Am Cars & Trucks
Engine has air supplied starter and has no air in fuel system why won't it start
Are you able to crank it?
Also check the engine block heater for functionality. It won't start else. Also I am assuming all fuel lines are primed? try cracking the fuel line to each injector as you crank it, and make sure the fuel delivery pump is working, This will also bleed the air from the system.
Oct 09, 2013 | Caterpillar D399 Generator Drive Engine
Cranks over wont start, starter stays engaged when key is released
Does the starter stop after a couple of seconds? If so this is normal. The vehicle not starting is not normal. Check the basics first. Do you have spark and fuel pressure?
Sep 14, 2013 | 2007 Hummer H3
Hi. I have a Briggs & Stratton 2800PSI gas pressure washer. I can get it to start, but after about 5 min, then it quits. I have cleaned the carb, change oil, changed plug, new gas, cleaned/checked...
if it wont start, check for spark.how you do that,ok take the spark plug wire out put it close to the sparkplug(use some gloves or something to insulate your self from get electric shot from the spark) find some one who pull the start rope, if you dont see any spark between wire and spark plug, tehre its not spark ,it will never start.you will have to remove the start recoil on the botton is like a damper whitch will have to be remove also ,on botton of it its like a coil whitch with the rotation of the damper when you pull the starter rope provoke the spark and send it to spark plug along with the gas combution get the engine started.that coil some time goes bad and have to be change.if you have electric starter. check the starter also.good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
You hold start botton it runs but no heat, you release start botton it stops
Check the wires to the switch on the motor, or the switch itself is not "clicking". Unplug the appliance before removing any covers.
Jul 21, 2009 | Whirlpool LGB6300 Gas Dryer
Starter wont stop spinning
The starter relay may be sticking on start. Get someone to start truck and when problem starts hit relay lightly wih hammer. A cheap voltmeter will tell you if relay is sticking or still energised from ingnition switch after key release from start position.
May 04, 2009 | 2001 Ford Expedition
Ford starter won't disengage even after the ignition is switched
sounds like to me that the ignition is bad and sticking on the start positon
Jan 04, 2009 | 1985 Ford Mustang
Caterpillar D399 Generator Drive Engine Logo
123 people viewed this question
Top Caterpillar Electrical Supplies Experts
Lawrence Oravetz
Todd Arndt
Todd Arndt
Ted Maxwell
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
