Question about Clutch Cable - 1984-87 Honda XL250R
Find battery in a honda 1985 xl250r - Clutch Cable - 1984-87 Honda XL250R
Valve adjustment for honda xl250r 1986
Hi Matt
05mm e=.08mm cold
Good luck.
Mar 19, 2014 | 1986 Honda XR 250 R
How to adjust valves on my 86 honda xl250r 1986
1986 Honda XL600R How To Adjust The Valves
instructions still valid for a 250 . ring local Honda dealer for clearances
1983 XL250R Wiring harness ,?
check all wires and plugs are same colour and same sockets ! both very similar bike !
Dec 04, 2013 | 1983 Honda XL 125 R
How do I remove the battery from a 1985 Honda Gullwing motorcycle?
I guess you mean 85 Goldwing GL1200Under LH side-panel unscrew retainer screw above battremove leads neg 1st, remove breather tube, pull battery out top 1st
Ride Safe
Bike-Doc
Jan 07, 2012 | Honda Motorcycles
1985 Honda XR 250 R hard to shift
Hi, Doug and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 Honda XL250R shifting issue
Shifting Problems Honda Dirtbike XL100 XR100 ETC
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Aug 27, 2010 | 1985 Honda XR 250 R
1985 xl250r honda road/trail twin carby Australian model need correct specs for float levels pilot jet main jet needle position mixture screw setting
There is only a manual for an XR250 but it may have the information you need. Go to http://www.carlsalter.com/motorcycle-manuals.asp , and download a (free) manual.
Jan 01, 2010 | 1985 Honda XR 250 R
1985 Honda VF 500 F need to hook up the fuel pump
Hi, Glwardberg for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1985 VF500F Fuel Pump
motorcycle fuel pump problem
Honda V30 Magna VF500C Manual
1985 Honda VF500F VF500FII Owner Manual
Jun 10, 2017 | 1985 Honda VF 500 F
Clutch Cable - 1984-87 Honda XL250R Logo
11 people viewed this question
Top Motion Pro Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Motion Pro Vehicle Part and Accessory Expert? Answer questions, earn points and help others
