I just got comcast internet and when i try to connect my netgear wgr614 router i lose my internet connection on my PC and my laptop picks up the netgear signal but is also unable to connect. i am sharing a computer with kids, please help me!
See for RESET button on the back of router when it is ON simply press the button for 30 Sec atleast this will reset to factory default state but later on set WEP security to restrict misuse
and all will be well after that pls also check the connection leads u are using to connect the modem to router and router to pc or some where
and pls get back to me if it helps or not !
and RATE ME WELL ! Regards
Zohail
Comments:
May 21, 2009
- also check the channel ur wireless router is transmitting on , if it is feeling interference in the channel try changing channel and see if it helps may be it is that problem in which its transmission get interfered by some nearby devices and drop frequently so channel hopping may resolve if u dont know how let me know i can guide u
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to...
(More)
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to the internet
My AT&T 2wire router thing loses internet everytime I try to use it. It does not matter...
(More)
My AT&T 2wire router thing loses internet everytime I try to use it. It does not matter where I go in the house, the wireless is always black instead of green on the router. Even when its on it will say i have limited connection or none at all. There isnt anything wrong with my laptop so I figure I just have a crappy router. What should I do seeing as my father bought the damn thing with my money and swears up and down its my new laptop and not the router, even though i know that isnt true
