Question about Acer Aspire 5500 5570-2609 Laptop
Laptop booting problem
I have an acer extensa 3000 laptop when you turn it on the power buttons turn on for a second then turns off. sometimes the screen comes on and displays the acer start up screen then turns off again i also noticed the cpu fan is not working which is more than likely my problem if so what is causing this?
  • marley mcelhinney May 21, 2009
    ram is fine checked all that, any idea what the problem would be with the fan
  • marley mcelhinney May 22, 2009
    yeah ive done all this already i want to know what component on the board could be bad to cause the fan to not work as i will repair it myself
    Scholar:
  • 70 Answers
Power On issues has to do with your battery or power pack. Your CPU Fan needs to get power from the Power Pack or batteries to come on
Follow this tests to ascertain which could be the probelm.
Take out your battery and connect your laptop to the mains directly and turn it on. If it comes on and boots to windows then your battery could be the issue. But if the same problem persist after powering your laptop without the battery then the powerpack or the motherboard or a component on the mother board could be bad.
Take another battery of the same model and put it in your laptop and turn it on. If it comes on and boots to windows then that finally means your battery is bad and needs replacement.
If after tryng the tests above and the problem still persists then you need to take your laptop to an authorized or certified acer solution service centre. Please make use of your warranty if its still within the period for free service repairs
Also go to this link to get additional support:
http://support.acer-euro.com/faqs/faqsearch.html
When you get there type in your model.
Posted on May 21, 2009
  • Onyebuchim Obike
    Onyebuchim Obike May 22, 2009
    Apparently when a component on a mother board goes bad it needs to be completely changed
    We have to deal with one issue which is causing the other to crop up and that is your PC going off barely after minutes of turning it on.
    TESTS
    If you have some technical knowledge on PC hardware then follow this step to check your CPU FAN.
    1. Take off the battery and unscrew the bolts on the base of your Laptop.
    2. Also unscrew and detach the keyboard taking off other components that would give you clear access to the mothereboard and CPU FAN.
    3. Check the CPU FAN connectors if they are properly seated on the motherboard. Plug in Laptop to the mains and start it up. Watch out for the CPU FAN if it comes up. if it does then your CPU FAN is ok
    Please if you dont have a technical knowledge on this steps please seek an assistance from a PC Technician to help you do this to avert more damages.
    For the PC going off barely after booting it then you need to perform a harddisk check from the BIOS menu.
    If the test shows a lot of bad clusters or irrepairable sections then its advisable to change it.
    If all this fails then you need to get a new motherboard and update your BIOS to the latest version.
  • 822 Answers
Check your RAM first. then check your cpu fan thats why your acer automatically off, due to overheating of processor.
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Acer extensa 5420 bios
Clean out the cooling fan/vents, etc. and try again. If the fan isn't turning, it won't boot up.
If that doesn't work, you may need to disconnect the power supply and battery and then hold down the power button for 30-60 seconds. This will discharge stored energy from your laptop. I'm not sure of the specifics, but this happens to mine every 12-18 months or so. Once you've done that, reconnect the charger and battery and try to power up again. It should work now.
If these steps don't fix it, you have serious problems.
May 02, 2014 | Acer Extensa 5420-5687 Notebook
I have an acer extensa 5635 with a full battery that wont turn on.
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Apr 21, 2013 | Acer Extensa 5635 Notebook LXEEA03007
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
How do I reboot my Extensa 5630Z?
Reboot? Like turn off and turn back on? If your computer is frozen, hold the power button for 6-10 seconds. It'll turn off, then just turn it back on.
Aug 21, 2009 | Acer Extensa 5620-4677 Notebook
Acer extensa will not boot to windows
What is happening when you press the power Button? Do you see any ligths, Any HDD moves? IF DOES.
TURN OFF by pressing and holding your finger on power button.
wait 60 sec. turn on and repeatedly press several times at F8 button.
If page opens on black and white, Use SAFE MODE.
wait til all line down. Then you will see windows opening in safe mode.
WHat ever you install last, remove, scan your computer for virus,spyware. when its finished, check your computer if need defragmentation. by Accessories>System Tools> Defragment.
If message comes such as windows will do this at schedule time or so.
Just turn off your computer using shotdown option (NOT BROWN BUTTON ON START) go to next arrow.
then turn on again see if windows comes back.
Goodluck
JMC
Aug 11, 2009 | Acer Extensa 4220-2148 Notebook
Cursor locks up on my acer extensa 5620
you need to go to your control panel then power options, on the power schemes turn the 3 setting you have to never.
let me know how you get on
Feb 16, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
