Remove bios password
Need to remove bios password on toshiba a505-s6960
  • 57 Answers
SOURCE: i need to remove my bios password
Try to locate the CMOS jumper on board. Set the jumper from pin 1-2 to 2-3 and return it back to 1-2.. This will restart your PC to default settings and erase the password.
Maybe this could help..
Mon =)
Posted on Nov 12, 2007
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
  • 5 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Posted on Aug 07, 2009
ginko
  • 19396 Answers
SOURCE: toshiba a120 bios password
It cannot be removed using software.
To remove the password you will have to remove the CMOS battery located on the lower side of the motherboard.
To access the battery the computer must be disassembled completely.
toshiba satellite pro A120 opening guide - Digital World
Laptop Disassembly Help
Posted on Sep 05, 2009
  • 23 Answers
SOURCE: keyboard illumination
ok marty assuming that u r using vista and that this illumination has a support software try this go to the start menu and at the search area located at the bottom of the menu type keyboard illumination or something similar i am sure that this thing is software supported and some support software name will pop up from where u can get it working try it best of luck
Posted on Sep 13, 2009
Toshiba a505-s6960 won't turn on
You should better go to the service center of Toshiba for the best solutions. The incident may have caused major issues to your laptop.
Regards, Mrityunjay.
Jun 19, 2012 | Toshiba Satellite A505-S6960 Core 2 Duo...
I have a Toshiba A505-S6960 laptop. Never have had a problem until today.......when I turn the laptop on it goes through the boot process but only makes it to the Toshiba logo screen with the F2 and F12...
It seems that your computer is not seeing your hard drive. This could either be because of bios settings or more likely because the hard drive has failed. If the unit is under warranty, call Toshiba support and describe the issue to them. If not, places like Best Buy can determine for sure the cause of the issue.
Toshiba Support
May 16, 2011 | Computers & Internet
How do I turn on my web cam on my lap top,toshiba A505-S6960
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?origin=new&ct=DL
Toshiba Website for Model. Selected Downloads and filtered to Camera.
Its the Toshiba Camera Application
Jan 19, 2011 | Toshiba Computers & Internet
How to install the base system device of Toshiba A505-S6960?
Download your drivers depending on your OS @ Toshiba Support Site, and install the necessary drivers.
Hope it helps.
Oct 20, 2010 | Computers & Internet
I just need to open my computer to weld a part inside, a Satellite A505-S6960 Toshiba
if your gonna weld a tower pull all hardware first because you will fry alot of things fuses caps boards and so on. Also note your gonna have a hell of a time welding soft metals. Go for a screw mount option if possible instead.
Sep 05, 2010 | Computers & Internet
Toshiba satellite a505 s6960 The service is temporarily unavailbe MSN How to Fix That ?
You can't fix it, the problem is outside your laptop: either the connection is blocked by the firewall of a router - try disabling it or connect your laptop to another one- or a server from MSN which has your account on it is actually down and you must wait for it to be fixed.
Jun 19, 2010 | Toshiba Satellite A505-S6970 Notebook
A505-S6960. Screens freeze when on a web page.
Replace the existing video drivers.
Good luck
Mar 22, 2010 | Toshiba Computers & Internet
Screen is black, but computer is on????
check lcd leds, you may ahve to open unit. and probably after, replace the lcd led circuit board. its just on the lower lcd part of the laptop.
regards
Feb 26, 2010 | Computers & Internet
The AC adapter input in my Toshiba A505 S6960 has broken after 75 days of use. Have you heard of this type of problem happening often
Hello there:
Yes this is a common problem it doesent happen a lot but yes it does happen What you need to do to repair it is tounplug thecomputer and remove the battery then open the case on the laptop and unsolder the old dc jack that is on the mother board and get a new dc input jack solder it back in place the piece costs about 15 dollars
Not real hard to do just takes time and patience ok?
I hope that this is very helpful for you.
Best regards Michael
Nov 20, 2009 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
