Trying to find out which wires go where?
Someone cut the connectors off so i have 4 wires coming out the back.i know 1 set goes to the speaker and 1 to the off/on switch.so what and where do i plug them?
    Problem Solver:
  • 10 Answers
Take one batery 1,5 volt and find out which 2 conectors are from speaker.You can so even find out which is + and which is -.The plus position is when speaker moves forward
Posted on Jan 07, 2014
3 Suggested Answers
billfox1966
  • 231 Answers
SOURCE: No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Posted on Jul 24, 2009
  • 11800 Answers
SOURCE: I need the wiring diagram
There are just 4 wires connecting in that jack: 2 grounds and 2 hot. You can identify them yourself directly either just by looking at the rear pins (where and how they are soldered on the board) after you remove the back cover, or by testing them with an ohmmeter (to the metal side of the jack): the 2 ground wires will show 0, the empty ones will show infinite and the hot ones will show 0 in the moment when you connect it then the resistance will grow fast toward infinite (if after that you reverse the polarity of the test wires you will get initially a negative resistance).
Posted on Dec 28, 2010
Need back speakers to go plugs been cut on radio
Car stereo speakers usually consist of 4 sets of colors one solid and one with a stripe in each set. The solid would be positive while the stripe would be negative. Easy way to figure out what wires goes where is connect one set and use the balance/fade control on stereo to determine the speakers position. Hopefully this helps . Good Luck
May 04, 2017 | Cars & Trucks
How to hook up autotek speakers in the rear for caprice classic 92???
Easy fix. The factory has fitted a special socket to connect direct to factory speakers. Just cut this off and connect the wiring from your new speakers to the factory wiring. Use insulated connectors or solder and tape up the wiring. Make sure that the speaker wire with a "trace" or line of colour through it marries up with the same wire in the car. Cheers.
Oct 17, 2013 | Car Audio & Video
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
How do you take the platinum speaker apart to resolder the volume switch led wires?
It is my pleasure to guide you.
1. Look for tacks or staples along the edges. If there are remove them and you should be able to left out the back, be careful of the wiring that should be attached to the connectors.
2. Looking at the back of the speaker the back could be inset about 1/4". Generally they have been slid into a slot cut into the sides and then the base is put on. Sometimes they glue the back in place. If the back is glued then you will have to cut the back along the sides, being careful not to go through very far being careful not to cut a wire. Problem is that there may be some pinned to the side. Try using a razor blade knife to cut through. Start along the edge next to the side and run the blade along the full side. Tap on the back to see if it moves, try not to break it. If it moves then repeat the rest the same way. The wiring to the connectors may be short so you need to be careful not to pull them off.
3. If the back is only held in by the bottom then that should be a little easier to get the back out. Look for screws or nails and simply remove them.
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 12, 2011 | Compaq Audio Players & Recorders
Where can I get a speaker connector?
After a few hours of looking on line and finding nothing I decided to make my own Sharp Receiver connectors. Here are the steps that I took:
_1349.jpgItems I used were wire strippers, wire snips, a file and a sugar free Rockstar (not pictured items: computer power supply, fine grit sandpaper and zip-ties).
_1350.jpg The first this I did was find the 4 pin connector and the 20 pin connector (some times a 16 pin) on the pc power supply and i cut the wires so that there was about 10" to 12" of wire hanging from each connector. These are the 2 connectors need from the power supply to use in your Sharp Receiver.
_1351.jpg This is the smaller of the 2 connectors (the 4 pin) and nothing needs to be done with this one. It fits perfectly into the back of the Sharp Receiver into the area labeled " surround sound". I would just zip tie the wires 3" from the connector and then 6" from the connector.
_1352.jpg The large connector I cut from the pc power supply is the one where all the work needs to be done. The Sharp Receiver requires an 8 pin connector for the are labeled "front speakers/center speakers/sub woofer". Notice the location of the clip for this connector and that it is centered, we need this clip to remain in the center when we are done so re are going to have to remove every thing from it except for the center 8 pins.
_1353.jpg What I did to get the connector to look like this picture is I cut the 6 pins off on both ends of the connector (you would only cut the 4 pins off both end if you are using a 16 pin connector from the power supply). after I cut those pins off I just pulled the wires out from the back side (they come out very easy after you cut the pins off). Now we need to get rid of the extra plastic where we cut the pins. Please view the next 2 pictures before you begin to do your cut.
_1355.jpg Notice how I left the plastic intact surrounding the 8 remaining pins we are using. I know that it seems like common sense to do it this way but there's people out there who would have cut the plastic so the pins we need are showing. There may be some jagged edged now from where u cut the extra plastic so to get rid of that we are going to use a file or a grinder. Don't grind the sides completely down though, I left a little bit of the ridges because the new ends have thin plastic walls and if you leave a little of the ridges, it will make it a little stronger.
_1356.jpg I tried to put my, now 8 pin, connector in the back of my Sharp Receiver and it was really snug. This is where the fine grit sandpaper comes in handy. just go around each of the 8 pins with the sandpaper, not a lot, just enough so the pins slide into the plug easy and doesn't wiggle. I used 2 zip-ties on this connector also to secure the wired a little more. Again, 3" and 6" from the connector. Now its ready to be plugged into the area labeled "front speakers/center speakers/sub woofer".
_1357.jpg This is what it should look like when you are all done making the speaker connectors for your Sharp Receiver. All that's left is to connect your speaker wires to your speaker connectors and then all of your components.
I only found 1 website that had the parts for this unit for sale and it was about $50 plus shipping for the connectors. You can get the computer power supply from your local area on www.craigslist.org for $5 or $10, you might have one lying around. If you have any questions or need additional help with this please feel free to email me: jlusk80 @ gmail.com
Thanks for reading my solution!
Jan 01, 2011 | Sharp HT-DP3000 System
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Apr 04, 2008 | Altec Lansing ADA 885 Computer Speakers
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
76 people viewed this question
 Grubhead
Grubhead
