Question about Element Electronics Televison & Video
Remote control problems trying toget the tv set up and run
4 Suggested Answers
FARADIO
  • 17 Answers
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
Posted on Apr 09, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
Lg lcd tv remote codeTRY ANY OF THESE: 140, 024, 040, 098,043, 259,260, 261
Posted on Jul 27, 2009
Remote does operate. Batteries new. Tv fine ?
mine does it. i pull it apart and cland it with q tips and alchohol and the battery connections put back toget and works you may need to recode it also.
Mar 09, 2015 | Televison & Video
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
TV Code for a universal TV remote to a Sharp
follow directions toget to code setup then keep pressing the on an off untill tv goes off press enter
Dec 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HI,
Mar 27, 2008 | LG 37LC7D 37 in. LCD HDTV
Intermittently Working Correctly with DirecTv
Update your Harmony remote control software on your PC to the latest. Go into the TV device settings. The software should recognize if there is an update to your TV's IR commands. Try the same things with the DVR.
It's also possible the TV and/or DVR are locking up due to IR commands that are being sent too quickly. The remote has a setting for the delay between commands sent to the same device as well as the delay between commands sent to different devices. Try adjusting these settings:
  1. In the Harmony remote software on your PC, click the "Devices" tab.
  2. For the "TV" device, click the "Settings" button.
  3. Click the dot next to "Adjust the delays" and click Next.
  4. Adjust the "Inter-key" and "Inter-device" delays to something higher and click Next.
  5. Follow the steps to save the changes.
  6. Repeat steps 2-5 for your DVR device as well.
-=Zzed=-
Feb 19, 2008 | Logitech Harmony 880 LCD Remote Control
Orion tv
Hi Gerald P, just posted we experienced same problem. Few minutes later my husband has finally solved our problem. Don't know whether you can try the same. We had an old FOXTEL remote, got onto FOXTEL site and instructions how to program remote to control TV.
Dowloaded instructions with code for TV (after trying a few tries, the fifth code solved it). FOXTEL control needs to be programmed with the code suitable to TV. By pressing "ON", "AV", Red button and Select (at same time) then put code in. Turn "OFF" then "ON" see if code complies. If not try another one until you get it.
By using the FOXTEL remote on the "AV" you can change the channels on the TV and adjust volume up or down as well.
Hope this can help you in your situation. Glad we are up and running again. Bye
Jan 23, 2008 | Televison & Video
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Televison & Video Logo
121 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
