Question about Philips Magnavox 27MS343S 27" TV
Philips model ptv915 model # 60P8341a
This tv is a 52" screen.  The tv sound goes off and on.  Tried bringing it up by model number without success.  Other numbers are Ser# 68081312
code  3712a25e
Makes a pop then picture disappears and comes back on in afew seconds, until no more sounds and picture. on power up tv screen turns blue for a second and then gone.
Posted on Feb 09, 2008
The SSB needs replacing.  I have done dozens over the years.
Posted on Oct 20, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Posted on Oct 19, 2007
Philips 52'' hdtv 1080p while watching it looses picture but still has sound
The back light inveterate board and CCFL lamps should be checked. Check and replace the faulty component. Back light inverter can only be replaced as card basis.
Jan 30, 2013 | Philips 52 In. LCD HDTV
Philips tv goes to the settings screen when you turn on and it doesn't go off for about 20 minutes
This could be a setting in the set or a microprocessor issue--I will presume you have unplugged the set for a while and tried that.
No model number is indicated here but you might consider calling Philips with the model number to see if it is a known issue in your set or if there is a software upgrade for this.
Apr 08, 2012 | Philips Televison & Video
Screen is black after the initial white screen that displays "Philips" Sound there but black screen with no picture Menu does not show either Nothing but black
I believe a firmware update can fix this issue. However to be sure I would need your entire model number, including the numbers after the slash. You can put that entire model number into Philips support website, http://www.usa.philips.com/#/headernav/consumer/
Once you get to your TV's support page, you can look on the right hand side and find the firmware information. First I suggest you read the Read Me file to familiarize yourself with the update process and what issues it fixes. Then you can download the firmware to your computer so you can upload it to a USB drive to perform the update.
Hope that helps!
Jul 19, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Suddenly without any problems for almost 2 years my remote control stopped working. I replaced the batteries, and still would not work. I went to Radio Shack and bought a universal remote, but I have tried...
I have very good luck with the Philips universal remote. The model number of the remote is SRP1003/27. I would suggest you find one the next time you are a a large discount store. The model number is near the upc code. Thanks for asking and show all hands of support!
Jun 01, 2011 | Philips 32PFL7332D 32 in. LCD HDTV
We are experiencing a problem with the sound on a flat screen Philips tv (model 26PFL5522D/05). The sound is really fuzzy. The tv is connected to free sat but the problem is still there when playing Dvds....
You should try to eliminate any physical cable issues by swapping the audio stereo cable from DVD to TV with another set and see if it persists when playing DVD. If the sound is fixed then it might be some bad cables you have. If it still sounds fuzzy, and your TV is still under warranty, I would consider calling Philips for customer support.
Check your manual to see how you can reset the settings back to default if at all possible.
Mar 03, 2011 | Philips Televison & Video
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
Sep 25, 2008 | Philips Audio Players & Recorders
How to clean the screen
Philips has Projection tv, screen cleaning fluid and a soft brush also to clean your set. You can buy this in most stores like Walmart or online. And remember that your screen have grooves in it so follow the patterns. I think most goes up and down. Hope this helps!
Sep 11, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
672 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
