Question about Dishwashers
Bosch dishwashers manuals
Drainage hose
3 Suggested Answers
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
  • 27 Answers
SOURCE: Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Posted on Mar 12, 2009
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
There are two hoses coming from my Bosch SHE45M06UC dishwasher. One is obviously the drain coming from the back of the unit, and the other is attached to the side looped and not connected to anything. I...
Many people realize the dishwasher connects to a little hose on the sink, it is called an air gap. However, many people wonder " The air gap is there to prevent the water from being siphoned out of the dishwasher. When water flows through the drain hose, it creates a suction on the water still in the dishwasher. The air gap, makes a hole for air to get in. That way, the water only leaves the dishwasher when it supposed to, when it is pumped out. Another benefit of an air gap is that if the drain hose becomes clogged, the dishwasher can still pump out the water. Instead of flowing through the hose, as it should, it can flow out the air gap and into the sink.
The dishwasher's drain line usually connects to an air gap mounted at the countertop level on the sink. The drain line continues from the air gap to either the garbage disposer or directly to the sink drain. If the drainage hose between the air gap and the drain is partially or completely blocked, wat
Aug 28, 2008 | Bosch Dishwashers
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
Drainage problem
Regardless of the brand dishwasher, they all have the same fundamental plumbing. so.. you need to check a few basic things first..
1. Have you cleaned the drain filter or screen?
2. Is the drain hose kinked or restricting water flow?
3. Is your dishwasher pump blocked internally or the hose entering or exiting it ?
4. Is the house drain ( meaning : where that hose drains water into) restricting water flow? ( back pressure or clogged?
Any one of these conditions will manifest itself as an undrained dishwasher.. Hope this gives you some things to check and you get your problem resolved...
Good Luck
Sep 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Bosch SHX45M05UC/48
Under the dishwasher you should she a hose barb by the drain pump assembly. One end of the drain hose hooks to the pump and the other to your drainage system.
Jan 13, 2018 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Sensotronic dishwasher will not drain
I think I may have figured out a work around (by accident).  Start a cycle (any cycle), once it starts hold down Scrub Wash and Delicate/Economy at the same time for 3 seconds and the cycle will immediately finish (counting down quickly then to CL) and it will begin to drain.  I had to do this 3 times(draining more each time) but the end result was a completely empty bottom of the Dishwasher. To be honest I think this is the first time the thing has ever been completely empty!  I wish I was joking...
Garth
Nov 05, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
